Washing machine smells when door is open - Washing Machines
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Hi, set your machine to 60 degree wash, add 1/2 a cup of Washing Soda Crystals and run the machine with no washing in at all...
Your drain will sparkle. All the gunge will be cleared from the door seal, and your washer will be lovely and clean...
Add 1 desert spoonful of Washing Soda to every wash... I sprinkle it along the crease in the door seal.
There was black spotted mold festering for ages and little by little this is disappearing and the washer is keeping lovely and clean... and my drain, which was always gungy and collected leaves, is now really clean and the leaves dont stick anymore, so easy to clear away.
Washing Soda Crystals come in 1kg bags and cost around 50p from most supermarkets... They stock it at Asda, Sainsbury's and Morrisons for deffinate.
All the best
sue
Posted on Aug 03, 2008
Does it smell musty, mildewy?
Add two cups of bleach, a load of white towels or sheets and do a hygiene wash at 80 or 90 C.
In future, after every wash, dry the door seal and leave the door open for a couple of hours to dry out. We leave ours slightly open all the time.
Nov 06, 2017 | Washing Machines
Mouldy smell when opening the door
Run a boil wash 95' with a box of Arm and Hammer baking soda and a 4 towels. No soap. That will get rid of the smell and sanitize it with the heat.
In future, after washing, dry the water in the ridge at the bottom of the door seal and leave the machine open for a couple of hours to dry the inside of the machine.
Mar 22, 2016 | Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Why is there a damp smell when I open the door?
Front load washing machines have to be hermetically sealed so they don't leak. Of course opposite of their top-loader cousins. :) In your case, Try cleaning the drum and the door seal and also remove any and all soap residue that you can find. Then try running an empty load with vinegar and/or Borax. You can try bleach, too if that doesn't work. When it's all clean and smells 'normal' again, be sure and keep the door cracked open when you're done using it from now on. Being closed and sealed all the time is why mold and mildew have grown, causing it to smell bad. I hope this helps! :) -Jason
May 02, 2014 | Samsung WF1124XAC 1400 Spin 12kg Load Eco...
I can't remove the detergent drawer from the washing machine.
After you are finished with the wash, leave the door open. Seriously.. you NEED to leave the door open so it can air out after each wash. Just a crack will do, if you close the door and seal it, bacteria will grow and make a bad smell. Your laundry room will smell bad for awhile at first but it'll clear out after several days. If you can't stand the smell, buy a kit in the soap isle that eliminates washer odor. Remember the kit is a temp solution, leaving the door open after using the washing machine is the real fix.
Apr 22, 2014 | Washing Machines
How do I get the mold out??
Without a proper model number I would say you need to clean your washer with a product called Affresh or Washerfresh. If you don't wipe the door dry and the boot dry, also dry inside the boot between the tub and front of machine. Also, when you finish washing, open the soap dispenser or better yet, take the soap dispenser drawer right out between washings to to let everything air dry and leave the door open. If the smell still persists you will have to change the door boot. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Terrible smell in washing machine
I used white vinegar in the machine and did a full wash.
I am subsequently not using a softener in the machine as I have found out that this is what caused the smell.
I now use white vinegar instead of softener and this has solved the problem.
Jul 01, 2008 | Washing Machines
Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Apr 10, 2008 | Washing Machines
Washing Machines Logo
847 people viewed this question
Top Washing Machines Experts
