Question about Denon DVD-757 DVD Player
Denon DVD757 manufactured in 2006. Won't power on at all. I have the lid off and have tried different outlets. any other ideas?
  • Denon Master
  • 508 Answers
I hate to say it, but if the unit won't power on at all, regardless of the wall socket it is plugged into, that it is a general failure of the switchmode power supply, which, unless you are 'tech. savvy' or have relevant electronics experience with PSUs, will require repair by an authorised service technician in a fully equipped workshop - one which specialises in Denon product sales and service.
However, you say you have 'the lid off' (I love that description) and plugged into different outlets. While you have the top cover off, and unit unplugged from the wall, you can examine (at least visually) all the electrolytic capacitors in the power supply; look for any bulging, crooked or leaky ones. These may be the primary cause of the failure in the PSU and since these are inexpensive components they can easily be replaced (they are not surface-mounted on the copper side of the board), either by yourself or by a workshop if you have no electronics experience.
This unit may be repairable, but at a cost. Get a quote from a service centre on the likely cost(s) to fix this unit so that you can make a firm decision on that basis. If you do go this route, insist on a technician's report from the workshop after repair and a written guarantee on the work done. This is up to you.
Denon is a quality brand and they have made many great audio/visual products over the last 20 years or so. Worth pursuing if you really want it repaired properly, irrespective of the age of the appliance.
Posted on Mar 23, 2011
I have a Denon 5803 and there's no power to the ac outlets and I'm getting no sound. I hadn't use it in a long while because I was overseas but nothing has changed.
Not to sure about the AC outlet problem but I have a Denon receiver and I have had the No sound problem with mine as well I've found it was the headphone jack you can get a headphone cable and spray it lightly with WD-40 then pull it in and out of the headphone jack a few times and you might have to leave it plugged in for about an hour if you can't get it to work another tip that might help is getting an air duster can and blowing out the dust I've found one or another to be very helpful because mine does this when it sets for awhile with no use Hope this helps out
Feb 16, 2015 | Denon AVR-5803 Receiver
Replace power outlet on 2006 Avalon
Try some of the Toyota parts outlets on the internet. Some of them show diagrams/ drawings of the parts IE: console . From there you can probably figure it out.
Dec 02, 2014 | 2006 Toyota Avalon XL
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Apr 03, 2012 | Hotpoint VBXR1090D Top Load Washer
No power to washing machine
Did you try another appliance in the wall outlet that the machine uses? That will isolate the problem to a power supply or the machine itself.
Often a faulty lid switch causes the symptoms you describe.
Jun 13, 2009 | Washing Machines
Only 1 of the power outlets on a Denon UTP-250 is live so the CD player and the power amp do not power up. I ma trying to get cover off and removed 4 screws - it seems stuck. i am looking for internal...
There are 6 screws, 4 at the side and to at the rear panel. After removing theses screws you can take of the lid.
Next to the transformator there are two glass fuses. The 500mA fuse is obviously broken, so just replace it and the power is bach up.
Tom
Oct 20, 2008 | Denon Audio Players & Recorders
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Denon 3801 Doen't turn on
try another power cable-----check on off switchand clean it with luricant contact cleaner from any electronics store.----after changing power cable and cleaning on-off switch---- try to disconnect it and connect it(system reset)
Aug 09, 2008 | Denon AVR-3801 Receiver
Denon DVD-757 DVD Player Logo
79 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
