My Thomson DTI 6021-25 DVR is constantly displaying the following error message when I try to access my library or even turn off the box: "Your hard disk drive is not yet ready. It will be available shortly." I've tried turning it off at the mains overnight, resetting it by switching off at the mains and pressing power for 10 secs when turning back on, and resetting it by switching off at the mains and pressing menu for 10 secs when turning back on. Nothing has worked. In the help settings menu Disk is showing as 'Not present'.
jyackle5
  • 8197 Answers
SOURCE: NEED A REMOTE CODE FOR
Sorry we are not able to help you with your problem at this time.
Posted on Jan 12, 2011
Benimur
  • 6966 Answers
SOURCE: A disk read error
The "clicking" and "disk read error" indicates a hard drive failure.  When the PC boots it can no longer read some files from or the entire HD.  The corrective measure would be to replace the HD and install your OS and programs. Alternately, you may try and reformat then re-install but then you would be operating with an unpredictable storage media and perhaps prolonging the inevitable.
If your reason for Safe Mode is to be able to access your files for purposes of backup, the constant trying/on-off just might worsen the condition of the HD. You can still try recovering by installing the HD in question inside a 2.5 enclosure to USB and install it as a removable device in a 2nd PC where you can try recover files.
Should you install a new HD and install the OS in your Gateway, you actually can use that to try and recover from the old HD. Recovery is 50/50.
Good luck and kind regards.
Posted on Oct 25, 2007
bestdarngood
  • 3037 Answers
SOURCE: screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Posted on Oct 26, 2008
  • 362 Answers
SOURCE: Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
Posted on Jan 26, 2009
Report
  • 50 Answers
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
No programme guide or Synopsis
try going to menu > set-up > box settings and then change the TV Guide type to the Freeview 8 day guide.
Nov 15, 2013 | Televison & Video
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
Dti 6300 cant get any power to it. not even standby. changed fuse. tried different power lead.
the power supply has failed . needs a service engineer due to shock hazard
Dec 10, 2010 | Thomson Televison & Video
Hi, Please can someone help? I can not find my manual for my Thomson DTI 6300 does anyone have the codes for a toshiba tv?
0538 0090 1538 0065 1319 0066 0100 0132 0744 0271 0247 0139 0225 0221 0648 1938 0039 0067 1194 1193 0748
These are the list of codes to try for your toshiba tv for connection to thomsoo dti 6300.
Hope i`ve helped
Dec 04, 2009 | Televison & Video
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Thomson DTI 6300 Digital TV Recorder freezes
try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
Dec 08, 2008 | Televison & Video
Thomson top up tv recorder Model 16300 wont record
Found this on another site. it worked for me.
Do the following:
Menu > Setup > Help
* Then press the Green Button (Even though it doesn't show as an option)
* Then press the Red button for a full reset
Hope this works for you.
All the best
Pottysam
Jul 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
Thomson dti 6300 16 top tv version box tuner works but programe lbrary where recordingd are available has frozen cannot access or delete
Hi! This is not a great solution and a bit long winded, but aimed at those who've lost the receipt! Start by recording a new programme - the box should still record. Now the corrupt recording is not the first one in the library. When you press library now, all appears to be well. You can find which is the corrupt recording by scrolling down slowly. The corrupt one should be the one with no thumbnail picture (plus it'll be the one that freezes the box up again!). Restart the box agan and press library. If you have recordings before the corrupt one you should be able to scroll very quickly past it and delete them now. Now the corrupt programme is at the bottom of the library list - you can't delete it but at least you can avoid it now...
Like I said far from ideal, but it works on mine. Still no word from Thomson. Hope this helps.
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Thomson dti 6300 freeview box will not come on just shows constant red/orange light flashing all the time, tried leaving power off etc....anyone know?
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Apr 13, 2008 | Televison & Video
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
