Televison & Video Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everything except change channels work on remote???
paul
Level 3:
  • Master 825 Answers
  • Posted on Mar 22, 2011
paul
Master
Level 3:
Answers
825
Questions
0
Helped
173915
Points
2202
Does channel change work on tv .? if so.....remote could be goosed.......
you can get a " 1 for all " remote for around a fiver .
worth trying.........
cheers
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
1helpful
Everything work except it will not change channels with the up and down button and says that the channels are not viewable but if you enter the channel number it works
Hi, This sounds like it is not a problem with the remote, but more like the channels have been "skipped" in the tuning menu of your TV.
To Fix, enter the tuning menu on your TV and set the "skip" or "clear" to OFF for all the channels you want to watch, then the program+ & - buttons should then work for you
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not...
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Polaroid 23" HD LCD TV
You need to select auto channel find from your tv menu
2answers
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
1helpful
2answers
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
