Question about Eureka 109A Easy Clean 2IN1 Cordless Stick Vacuum
My Eureka Easy Clean 2 in 1 model 109 cordless vacuum cleaner shuts off after 2 - 3 minutes. Turning it off and back on gets 10 seconds more. I have to repeatedly turn it off and on to finish the job. The battery is NOT discharged.
  • 2 more comments
  • doodrman Mar 22, 2011
    This is a cordless unit as I mentioned in my question. Your fix is not applicable.
    My unit is cordless. Your fix does not apply.
  • doodrman Mar 29, 2011
    Sorry for the delay. I have two of these units. Both worked worked great for first few weeks before the problem started to occur with both machines. The machines are fully charged before each use. According to the manual, there is an electronic circuit that shuts the unit down to prevent overdischarge of the battery pack. I opened one unit after amany repeated off/on cycles to ccheck the voltage on the pack. Even after all these cycles the the motor seemed to run as if the unit was fully charged. I read 9volts. The pack consists of eight 1.2v Electrolux batteries wired in series. The charging unit is rated at 15v. I think that the electronic circuit is shutting down prematurally. What do you think?
  • Gary Higgins Jul 04, 2012
    You are correct. The problem is the electronic over current circuit that prevents a possible overheating of the battery pack. My unit will run for 10 - 15 seconds and then shuts off. The over current sensor is reset by moving the power switch to the "OFF" position. If you turn the vacuum back on it will run for a few more seconds before shutting off again. There is a small circuit board in the vacuum that contains the over current protection circuit. It uses an NXP Semiconductor HEF4001BP quad 2-input NOR gate. If you are good at soldering you might try replacing this chip. Otherwise, buy a new vacuum. The problem is not in the thermal circuit breaker located in the handle. I have bypassed the breaker and the problem still occurs.
  • 1,998 Answers
First you would check the cord to assure there are no cuts or damage to the cord this can cause this situation as well as where the cord goes into the unit having been pulled by the cord would also cause this same situation following this you would then follow to where the cord goes into the machine and check the terminal connections to the motor itself as well this is basicly a power issue and you would resolve that issue by finding which piece is where the power stops if you were to take a voltage meter and measure the amount of current going into the motor if the motor has none then you know that your problem is before the motor and most likely in the cord if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations in the future. Also if the unit is still under the 1 year warranty on this unit do not attempt to repair you would void your warranty if you did. Instead contact either the place you bought the unit or message me back and I can look this information of how to contact the manufacturer Thanks again for using fixya
Rick
Posted on Mar 22, 2011
  • Rick Ead
    Rick Ead Mar 22, 2011
    oh sorry didnt see you posting about it being cordless then it would have a battery pack correct in which you would then test your rechargeable batterys and the wiring going to the motor and the switch itself it has a 9.6volt battery rechargeable battery.
    The life of rechargeable batteries can vary between several weeks to several years, depending on the type of battery, the way the batteries are charged and discharged, and the conditions they are used in. the issue is still the same with the wireing its just differnt from it having a cord to not having one there is a bad connection point between your battery area and your motor or your switch take out the batterys and perform continuity tests on the wires going from the battery compartment to the switch and also to the motor the switch recieves power from the battery and then the wireing then goes to the motor if you have any further questions message me back Thanks Rick
  • Rick Ead
    Rick Ead Mar 24, 2011
    hello awaiting your reply on how you made out with your unit thanks Rick
Eureka True Clean vacuum cleaner manual
Contact Eureka local dealer , or go to Eyreka Website , for info.
Mar 16, 2015 | Eureka Vacuums
I have a Eureka Easyclean that will not hold a charge and want to replace the Electrolux battery it comes with and cannot find one. Can you?
Sadly, the battery is not replaceable on this unit. According to the schematic, I can get almost every part but that. This is common with all of the cordless units too. Batteries are usually the same price as purchasing a new unit. If the unit is more than 1 year old, sorry to say its pretty much garbage. IF the unit is less than one year, it should be under warranty and replaced by your local Eureka/Electrolux dealer.
Also, not all hope is lost on this unit, if there is an obvious burn, or connection issue, a little bit of solder should correct the problem.
Good luck!!
Jan 24, 2012 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
The machine shuts off after 2 - 3 minutes. Turning it off and back on gets about 10 secnd run. The batteries are NOT discharged. Have to it off and back on repeatedly ot finish the job.
The problem is not the battery pack. It is in the electronic over current circuit that prevents a possible overheating of the battery pack. My unit will run for 10 - 15 seconds and then shuts off. The over current sensor is reset by moving the power switch to the "OFF" position. If you turn the vacuum back on it will run for a few more seconds before shutting off again. There is a small circuit board in the vacuum that contains the over current protection circuit. It uses an NXP Semiconductor HEF4001BP quad 2-input NOR gate. If you are good at soldering you might try replacing this chip. Otherwise, buy a new vacuum. The problem is not in the thermal circuit breaker located in the handle. I have bypassed the breaker and the problem still occurs.
Mar 22, 2011 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
I keep my vacuum on the charger all the time and seems like does not work right after all. Stoops after 30seconds of vacuuming. I do not if this is batteries or something else. Please advise. thank you
The problem is probably not the battery pack or charger. I had the same problem and it is in the electronic over current circuit that prevents a possible overheating of the battery pack. My unit will run for 10 - 15 seconds and then shuts off. The over current sensor is reset by moving the power switch to the "OFF" position. If you turn the vacuum back on it will run for a few more seconds before shutting off again. There is a small circuit board in the vacuum that contains the over current protection circuit. It uses an NXP Semiconductor HEF4001BP quad 2-input NOR gate. If you are good at soldering you might try replacing this chip. Otherwise, buy a new vacuum. The problem is not in the thermal circuit breaker located in the handle. I have bypassed the breaker and the problem still occurs.
Oct 08, 2010 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
I have a Eureka The Boss Smartvac. I was vacuuming and it just went off. It was on one second and then off the next. I changed the bag thinking it was full but it didn't go back on. What's happening?
it overheated, just have to wait a few minutes, maybe change bag and have a look at filter in bottom of chamber where bag is located, clean it if its really dirty. lack of flow will cause the vacuum to overheat.
Jul 04, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Need replacement part, maroon cover top handle of Z570 cordless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and you do have the model # Z570 but I would suggest that you contact your local vac dealer and they should be able to tell you where to get it or they can order it for you, you need to supply the brand name and model # in order to get the part. As an example, you can use the Eureka website as: (if the brand name is Eureka)
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Eureka 109A Easy Clean 2IN1 Cordless Stick Vacuum Logo
245 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
