Question about LG 32LG30 32 in. LCD HDTV
Lg lcd tv humming sound which varies throughout a programme no rhymn or reason to it but especially noticeable when quiet part of programme
    Sergeant:
    Champion:
  • 285 Answers
Alot of Tv's have this sound that comes from the speakers or the back of the set. Its normally when the transformers inside are underload they start buzzing. this could come from the Powersupply or the Inverter. When changing channels they change their tone sometimes.
Posted on Mar 22, 2011
  • melanie dew Mar 22, 2011
    how can i stop this humming/buzzing?
    it happens during a programme not changing the programme
    melanie
  • Jonathon summesfield Mar 22, 2011
    It just depends on how old it is, if its fairly old then it might need some solder joint reflowing as dry joints could be causing the tv to draw more power than the transformer can handle thus making it buzz, in the case of the inverter buzzing the CCFL bulbs that light up the screen could be drawing too much current causing it to buzz.
LG 32LC2DB television says No Signal after 30 min
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
1989 Mazda MX-6 sometimes starts other times it doesn't sometimes if you turn key on and off the car starts no rhymn or reason
Try wiggling the key when it's running.(By your descripiton,it sounds like the igntion switch is possibly worn out.)
Oct 07, 2012 | 1989 Mazda MX-6
Samsung UN40ES6100 HDTV has a sound delay that I can't get rid of
My LCD panel is broekn? is it work to replace the LCD panel ?\
The Replacement LCD panel code is BN95-00604A
How to do the LCD panel repleacment
Jun 12, 2012 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a ?buzzzzzz? from the back of the TV. As I worked it for more then 5 hours I...
I'm pretty sure that the buzzing sound is a not normal thing for an LCD TV. I sell Flat Panels during my spare time and it should be as quiet as a CRT types. It is more likely a defect and you should return it ASAP.
Hope this helps.
Oct 23, 2010 | Televison & Video
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
Sound problems with my t.v
Call your LG dealer to arrange a service call, depending on the exact model you have there is a modification for the audio reponse, also you may need the software updated & re-set to cure the sound varying every 30 seconds.
Nov 01, 2009 | LG 42LC2D 42 in. LCD HDTV
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
LG 32LG30 32 in. LCD HDTV Logo
594 people viewed this question
Computer Repairing
Computer Repairing
