Question about Hotpoint Ultima WF860 Front Load Washer
Its showing f 12 on the display - Hotpoint Ultima WF860 Front Load Washer
    Brigadier General:
  • 6,277 Answers
'F12' for Hotpoint washers decodes as 'no communication'- very helpful! Often the cause is poor contact between cables/plugs and modules (PCB and individual items). Probable cure is a service call and engineer re-seating the plugs/cables/connectors, sorry ;-0(
Good luck,
John C
Posted on Mar 22, 2011
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Why won't all my favorites display? Only showing 12 of 38.
Your favorites bar will only show up to 12 at most due to the amount of room that you actually have on the screen. Simple click the Favorites button or go to Tools>Favorites to see all of them.
Jan 24, 2016 | craigslist.org
Radio Shack atomic clock 63-1438. How do I set it for 12 hr. time rather than 24 hr.?
Some clocks of this type have a 12/24 selection switch on the back.
Dec 28, 2015 | Home
How do I add 12% to 30 (for example). This new Casio HR-100TM has the WORST user guide I have EVER seen!
figure 30 plus 12% (the percentage amount will show 3.6) plus and display will show 33.6
or 30 x 12% plus
Sep 29, 2015 | Casio Office Equipment & Supplies
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Hotpoint Ultima WF860 Front Load Washer Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
