Question about Fisher and Paykel Washing Machines
I switched on the machine, and as soon as the power came on it made a strange noise, almost like something blew up. Then, I programmed the machine with the settings I wanted just like I usually do, and when I pressed start, I got that very same noise. Then a peep-peep noise now started and the spin cycle light turned red and I couldn't do anything. So I switched off the machine and when I plugged it back in, it was dead. Any ideas? Thanks, Kind regards, Martha
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 22, 2011
Why is my sewing machine making strange noises ?
can you explain more about the noise it is making ? maybe something is caught some where else
Feb 16, 2015 | Janome Memory Craft 9000 Computerized...
Smeg Dishwasher Humming Noise
Hi olsworth,
I think you may have something hung up in the pump.  This is a bad situation.  See if you can remove the dish baskets, and remove the strainer cover in the bottom of the chamber and see if something is in the pump drain area. I am not real familiar with the Smeg, But I do know that humming is related to the pump motor in a strain. I will study this more and get back with you soon.  Please do not vote yet.  I am wanting to get this solved for you, and it may take a bit of study on my part to get you an answer.  Please give some feedback in to what you are finding on your end.
Oct 16, 2007 | Smeg DWI614 Built-in Dishwasher
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
"General Error"
First step is check inside the machine for crunched up paper at both ends of the print carriage path. You may need to start the machine and pull the power cable out as soon as the printhead starts to move. This allows you to move the carriage out of the way.
Apr 08, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Golf 2002 mk 4 130 making a strange noise when revs up
If you think it's the timing belt, get it replaced or inspected.
Even though there are other things that might make a noise, the damage you might do by having the timing belt fail while the engine is running are not worth the risk.
Oct 19, 2009 | 2002 Volkswagen Golf
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
LAT9235AAE
Put the tube back on switch and remove other end from tub. Then blow and see if switch is working
Sep 23, 2017 | Maytag 22 Cycles Topload washer, SAV365Z
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
