I have a Panasonic PT 52lcx66...Had a bulb replaced that was definitely bad...now bulb may or may not light. Completely Intermittent . Has been checked for bad solder joints & connections...everything appears to be good. Could the new bulb be causing this or would it most likely be something else . Thanks JM45
  • jffryjrdn Mar 22, 2011
    Thanks for your help...yes I did replace the bulb & housing & performed the reset procedure . I'll try a ballast board if not too expensive. JM45
  • 10,594 Answers
If only Bulb was installed in old lamp casing to save the money then it is the Bulb that is causing problem because low price bulb does not last longer and gives problem very soon so put Panasonic original lamp in tv to get it fixed.
And if you replaced complete Lamp Assembly (TY-LA1001) from Panasonic then make sure lamp timer has been reset in tv as per instructions supplied in lamp box/ packing. Now if lamp is original and lamp timer has been reset then Ballast Supply is only cause of such intermittent problem and may require to replace.
Hope these info will help.
Thanks.
Posted on Mar 22, 2011
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
How do I replace the lamp and housing unit on my panasonic PT-52LCX66
You need a TY-LA1001 lamp assembly. Our Panasonic TV Lamp and Bulb Installation Guide shows how to change the lamp and has links to Panasonic Users Manuals.
easyab@hotmail.com
Feb 11, 2011 | Panasonic PT-52LCX66 Projection Television
Gren light of power is flashing but not powering up
Have you replaced the lamp it sounds like a bad lamp issue this lamps are good for 2-3 years of use the first thing I would do is replace the lamp is should solve your issue here is the lamp you need
http://cgi.ebay.com/PANASONIC-TY-LA1001-TV-LAMP-REPLACEMENT-BULB-TYLA1001-/320581342030?pt=LH_DefaultDomain_0&hash=item4aa423134e
Sep 21, 2010 | Panasonic PT-52LCX66 Projection Television
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
Need bulb
Post your model number and I will post a link where you can get one at.
Apr 26, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
