Hello. I have a xerox docuprint 2125. When i go to print it says that there's a paper jam and to open the front cover, but there's no jam. I remove the paper tray, open the front cover, it resets and the same thing happens again.
  • 41 Answers
This printer has a straight flow through path.
* Situate the printer so that you may clearly get to the back of the device.
* Open the rear door path and check for the presence of any paper in the path there.
* If none. Then you need to check the area around the fuser.
* Permit the printer to cool for several minutes.
* Release the side catches and open the top of the printer.
* pull out the cartridge.
* inspect the area around the fuser. You might see a paper jam there. Clear and reassemble.
Posted on Mar 22, 2011
Xerox3124 jammed paper
Hi
Open and close the front cover.Turn the printer off and on.This automatically exits the paper from the printer.
You can also remove the stuck paper by gently pulling it out straight.
If there's no stuck paper,clear any print queues.
Disconnect the printer completely from power and then re-connect again.
Now try printing.
Mar 25, 2012 | Xerox Phaser 3124 Printer
Masalah paper jam bila mahu prin kertas,jadi apa masalah printer saya?
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Apr 01, 2011 | Xerox DocuPrint C525A Laser Printer
Recurrung jam message
if there's no paper jammed then a sensor might be dirty, the printer has several sensor along the path of the paper to detect its flow.
Mar 30, 2010 | Xerox DocuPrint C525A Laser Printer
Fuji xerox docuprint c3055dx printe
please check the pick up roller on the unit. maybe it is worn out. if so, please replace it.
Mar 05, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Aug 30, 2009 | Xerox DocuPrint 203A Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Paperjam Xerox DocuPrint P8
in any side you look the jam answer me and give you the solution
May 13, 2009 | Xerox DocuPrint P8 Laser Printer
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
90 people viewed this question
k24674
jasbo
jasbo
