Ive just got a new computer and added some additional sata drives, one drive shows up in widnows and in bios but other does not show in windows and in bios only sata slots 0,1,2,3 are shown. i cant find any way to enable slots 4,5,6 in bios.
  • 4 Answers
Hey, if i was you i would first try a bios update, it may be that even thought it is a new computer the bios it was shipped with was not up to date. This may solve your problem, any questions feel free to email me at
Posted on Aug 03, 2008
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Show blue screen and show error 0x0000007b during installation windows xp
I assume your trying to install windows xp on a somewhat newer computer. This will not work without some tweaking. The reason you are getting this error is due to the fact your computer most likely has a SATA drive as opposed to an IDE. Windows XP does not natively support SATA drives.
First thing you can try is go into your BIOS and change your hard drive to emulate IDE support (To get to BIOS, while the computer is booting you will need to press the key is asks for to enter setup/BIOS usually F1 F2 F10 or del)
Here's a video I found on youtube that explains it, you want yours set to IDE. After this is set, XP should install just fine.
The other option is to build a slipstream XP disc and integrate sata drivers into it so that you can install XP on a computer with sata. This is much more advanced and I would try to emulate IDE mode first.
Leave comments if you need additional assistance.
Aug 04, 2011 | Computers & Internet
My Pioneer DVD-RW 109 ATA does not show in computer list with windows 7, any ideas
Do you mean that it doesn't show in the "My computer" section?
Did you install this yourself? Or did it come with the computer.
If you did it yourself, you may have to check that the cords are properly connected. Also, if you are adding it as an additional drive, you may have to enable the SATA connector it's connected through the BIOS. Like SATA-0 may be your HDD, SATA-1 may be your primary DVD Drive, and if it's an additional one SATA-2 might be that one.
Please Rate.
Jul 08, 2011 | Computers & Internet
Ive recently installed a new harddrive in my computer and now I cant get windows xp to set up
check to see if the drive is showing up in the bios.
if the drive does not show up in the bios then you will need to check the cables and jumpers(if its ide)
if it is a sata drive, the cables with no clips come loose easy, check that.
if the drive is showing up correctly in the bios but windows xp just does not want to setup, usually this means that the drive has to be wiped and formatted first, try some eraser program or use the fdisk or cfdisk command with a live linux disk
Oct 16, 2009 | Computers & Internet
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Oct 28, 2008 | MSI P965 Platinum Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
SATA Disk Problem
Is it a SATA II drive?
If so, you need to jumper the drive to "downgrade" to SATA I before the Via controller will recognise it.
WD5000AAKS needs to jump 5+6. I don't know about other drives, but I'm sure you can find it.
I hope I've made your day, just as this info did to me when I found it!
Nov 02, 2007 | Foxconn MB KT600 600A01-6LRS Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed)
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
SATA won't work
I think you're saying you've got XP installed, but the second drive isn't showing up.
You need to format the drive.
Right-click My Computer/Manage/Disk Management.
The drive should show as unallocated. Right click and select format. It may ask you to create a partition first.
Oct 16, 2007 | Intel Motherboard
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
