Question about Kenmore 62622 Microwave Oven
I have a Kenmore microwave oven model number 721.80419500. Both over range light bulbs burned out. I went to Sears and got 2 new bulbs today, installed them, and they still won't work. What is wrong?
  • Joe Perretta Mar 26, 2011
    I checked for everything as suggested but there were no obvious breaks or burns or any indication of a blown part. does this mean the main controller board is bad?
    Hi Kevin, Thanks for the information. Everything else works fine except for the under side lights. We heard a pop, both bulbs blew. I have looked at and did continuity checks on all of the wiring for lights and all is good. So this fuse is only for the under side lights? The inside light still works fine. Also where is the fuse found? I looked for one when I had it all apart and did not see one. Please let me know what you think. Thanks!
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
The control board cannot go bad just because the bulbs are burned, first check the wiring harness for any burnt wires, if that's fine then it is the fuse that is bad and needs replacement. You can also check this parts picture to locate the fuse. Please get back to me if you have any other questions.
Kevin
Posted on Mar 26, 2011
  • Kevin White
    Kevin White Mar 26, 2011
    Yes right thats the fuse that needs replacement
    President:
  • 2,468 Answers
This unit was produced by the Amana corporation for the Sears Kenmore brand,there are 2 different electrical schematic diagrams,i would first remove the top cover of the unit in question,then carefully discharge any residual voltages from the internal high voltage capacitor,then check for burned or poor connections on the control circuit board that lead to the lamps you just purchased and also the interlock switches where the door closes,if one of these is mis-adjusted the unit is not suppose to operate at all,but sometimes a mis- adjustment will allow certain operations to continue and others not to
Posted on Mar 22, 2011
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
The light went out an the turntable won't stop when I close the door...i tried to push clear, but it still turns. I couldn't find my model number on the below pull down, but my model is 721.8001...
721.80019401 (without spaces) is the correct model number.
If it was the cooktop lamp(s) that went out, I would suspect that it shorted, damaging the control circuit board.
We see and repair this problem on a regular basis with our $39.95 repair service.
Or you can order a new control circuit board (part number 6871W1S354A) for $75.80 from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Kenmore 80012 Microwave Oven
Light Bulb Blew - blue spsarks. Replacement does not work. shorted out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Or you can order a new control circuit board from the
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
Jan 22, 2011 | Kenmore 80412 Microwave Oven
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62709 Microwave
The 5-digit number above is not a complete model number.
If you can post the full model number I can probably give you a link to the explode view, or you can find it here: http://www3.sears.com (the 3 is correct)
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Nov 21, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens
The installation manual will cover that. If you don't have yours, you should be able to order it via Sears parts online: http://www3.sears.com/ You will need your full model number to look it up.
Mar 04, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
122 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
