Savin C2410 copier. What service code do you used for to reset the Photo conductor message on the LCD display?
  • 5,370 Answers
You can try this reset procedure.------You will have to go to SP mode.To go to SP mode.Try this as follows:--------- Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear message on display.----------
Keep updated.Thanks.Helpmech.
Posted on Mar 22, 2011
Error code sc571
You need to fill the oil tank with "silicon oil" i'm I'm not sure where your're from, but where I am its virtually impossible to get it apart from a dealer or a company such as Katun.
Once you have replenished the oil the error code will have to be reset, I would only let an experienced tech do it as you have to enter the service mode on the machine, and pressing the wrong buttons can cause untold problems.
Sep 20, 2012 | Savin C2410 Cyan Toner Cartridge...
Savin copier c2410 error code 421?
http://www.restoreguard.com/p/error-421.html?keyword=Error%20code%20421&gclid=CNTmo4vZ26UCFYtspAod1CIj0w
very common fault with win 7 click the above link and it will install the corrupt / missing program files
Dec 08, 2010 | Savin Office Equipment & Supplies
How do you reset the savin 8035 sc542 code after thermistor is replaced?
Press the yellow button ( reset button ) then press 107 then press and hold the red button (stop button ) for about 3 sconds until the display changes. Touch copier on the display screen. Now turn the copier off using the on off switch on the left front side of the copier. If the cold comes back the Thermostat in the fuser is most likely tripped and would need to be replaced.
Apr 29, 2010 | Savin 8035e Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Reset Photo Conductor Kit
Hi!
For step by step procedure to reset Photo Conductor counter please see the following link---
Photo Conductor Counter Reset
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 02, 2009 | Lexmark E450dn Laser Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
Resetting the fuser oil message
Well, all you need to do is fill the tank on the back right of the machine. The oil pump has to pump it up to the sensor in the fuser. It will eventually go out, or you will get an SC570 code.
Mar 04, 2008 | Office Equipment & Supplies
69 people viewed this question
jasbo
jasbo
