FujitsuSiemens Scaleo T Computer I have just bought a Hitachi Deskstar disk as a second drive how do i connect it? What leads do i need does it go direct off motherboard or is it set up as a slave to teh original disk does it matter what bay it goes in?
    Sergeant:
    Champion:
  • 239 Answers
There is a set of instructions here for installing a hard drive. First of all disconnect the machine from the power and peripherals and if possible work on a wooden surface as it will reduce the likelihood of static discharge which can fry your machine!
http://www.hitachigst.com/tech/techlib.nsf/techdocs/4DD4DCCA11DE5EB186256D6A0061C8A8/$file/Installposter.pdf
It is normally quite a simple operation if you can use a screwdriver but you do need some extra mounting screws which you should be able to buy for a few coins at your local computer store.
You need to remove both side panels to access the chassis in order to mount the drive. There should be several spare bays in the machine and it doesn't really matter which you use as long as the cables reach.
Make sure the jumper on the drive is set to 'cable select' (use a pair of tweezers if necessary) It will tell you the correct setting on the plan on the face of the drive. When you have installed the drive physically into the chassis then you need to connect the cable. Most cables have 2 mounting points for drives. The end one is the master and the middle the slave so you need to connect the middle connector (often grey) to the hard drive. You also need to connect a power supply, there is usually a spare in the wiring. Both these connectors will only fit one way so be careful.
When you boot up you need to go into disk management via control panel, administrative tools and set up the disk (format) usually to the NTFS structure. You may want to partition the disk at this stage as well.
After this it should be ready to run
Posted on Mar 22, 2011
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
Hi, I have problem here. I just bought Hitachi Deskstar 7K1000.C. It works fine at first, but one day latter some clicking noise appear. It detected in BIOS, but then make my Windows take a very long time...
The short answer is the drive is having trouble calibrating itself, and should be sent back under warranty for replacement.
There are things you could try to recover the unit, but why risk voiding the warranty only to wind up with a questionable drive afterward?
Mar 17, 2011 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Restarts only the pc, and the train and nothing. I get error disk
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Mar 10, 2011 | Hitachi Deskstar 7K80 HDS728040PLAT20 40GB...
My hitachi hard drive gont tern on can u fix the
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 03, 2010 | Hitachi 1TB 7200RPM 32MB BUFFER SERIAL ATA...
Hard desk can't dectet the hard desk
I would recommend TechRx, inc. for a free exam of the drive. The Hitachi Deskstar drive has some unique featues that allow a data recovery company to do firmware repair easier than other brands of drives. When a drive is not detected, it could be due to NVRAM corruption on the drive. If you find my answer helpful, please leave feedback/rank.
http://techrxgb.com
Aug 17, 2010 | Hitachi Deskstar 7K250 80 GB IDE Hard...
I want put my Hitachi Deskstar 7K250 80GB Hard Drive from a t2885 emachines on a HP/Compaq K8N8X-LA mother board without losing my data.
You won't loose your data Why wold you think you would? once data is written to a hard drive it remains there until it is removed be a user, it works on the same principlea a floppy, the magnetic coating on the surface of the anodized disks inside of the HD are written to and retain memory of the data, the only things in a computer that won't keep their data are the RAM chips which need electricity running through them to work.
Dec 07, 2009 | Hitachi Deskstar 7K250 80GB...
HItachi deskstar Hard disk 80gb 7200 rpm
check the power cord of your hard disk. It should be tight not loose, if not solve then change the power cord.
Nov 25, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Bought a 500gb hard disk only registers as 128Gb when in computer. how do I recover and format this oem drive?
This would be a bios limitation. Formatting wont' fix the issue. Check your bios and see if it supports "lba" . Certain manufacturers offer "Drive overlay" which will allow you to use the space ..
Nov 14, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi Deskstar® T7K250 250 GB Hard Drive
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
