Question about Panasonic CX-DP610 6-Disc CD Changer
I have a panasonic 6 disc cd changer in trunk of my car. I keep getting a E1 error message which blinks for about 5 seconds then I hear the unit switching to the next disc in the cartridge but the E1 error will still be displayed.
The Marv
  • 72 Answers
SOURCE: vcd/mp3 player always says "no disc"
First try and clean the laser with a Q-tip with rubbing alchol on it. gently wipe the lens with the Q-tip. Then allow to dry for a couple of seconds. Try again if problem persists. Try to get the disc spinning wth your finger. While spinning clockwise close the lid and see if it takes off. If it does you have a bad spidle motor and it will need to be replaced. If it does not respond to either. I would consider replacement. The cost to repair by the time you pay a tech and parts you could get a new one with warranty. Generally if these need more than just a cleaning most people just replace due to cost of repair.
Posted on Aug 07, 2006
simplemitch
  • 752 Answers
SOURCE: Panasonic SA-AK95 (cd changer)
F61 is a power source error. If it got water in it, it's a paper-weight. There is NO repair for water damage...
Posted on Sep 22, 2007
  • 6 Answers
SOURCE: Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Posted on May 01, 2008
thaurfen
  • 623 Answers
SOURCE: I have a Panasonic SA-AK300
panasonic manual http://service.us.panasonic.com/OPERMANPDF/SCAK500.PDF
Posted on Aug 04, 2008
  • 108 Answers
SOURCE: Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Posted on Sep 19, 2008
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
2010 Mazda 5 CD changer not working
if you have a genuine unit it may be connected to the CPU or need resetting after the battery change.
Dec 12, 2013 | 2010 Mazda MAZDA5
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
How do you clean the laser please
You will probably have to disassemble the changer to access the laser lens. You can clean the lens with q-tips and rubbing alcohol. Be sure to be very gentle or you can scratch the lens which will ruin the lens.
Dec 29, 2011 | Panasonic CX-DP610 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Blaupunkt IDC-A09 5-Disc CD Changer
This is the only site that I found that deals with that brand.
http://www.midwestelectronics.com/index.php
Jun 09, 2009 | Car Audio & Video
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Try turning your cd disc over, it may be installed upside down!
Jan 06, 2009 | 2001 BMW 5 Series
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Panasonic CX-DP610 6-Disc CD Changer Logo
61 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
