Question about Husqvarna Designer I
.legge@hotmail.comMy designer 1 Touch Screen
    Scholar:
  • 89 Answers
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Posted on Mar 22, 2011
  • Jaimie
    Jaimie Jan 07, 2014
    Hi, I hope you get the message. I tried what you said but I can't get the crosses to turn green--nothing happens when i touch them with the stylus. Is there anything more you can tell me that will help me. The touch screen appears to be frozen. I can't select anything from the touchscreen
How happy are people who have changed their Husq. designer 1 floppy to usb.
We have done about 30 of these jobs here in Edmonton Alberta.
I am unaware of any unhappy customers.
Central Sewing machines
Oct 06, 2014 | Sewing Machines
Designer 1 touch screen frozen
the touchscreen cable may have come loose or perhaps the touchscreen has failed. take the machine to an authorized Viking repair dealer to have them troubleshoot it.
d
Apr 14, 2014 | Husqvarna Designer I
My Designer 1 sewing machine touch screen is frozen and won't calibrate or respond to touching. This is intermittent behavior. Sometimes it works, and sometimes not. Can you tell me what this is
Sounds to me like the plug-in connector from the screen is not firmly attached to the motherboard (directly behind the screen but inside the machine). This kind of problem doesn't take a factory trained technician. Ask various sewing machine dealers to whom they subcontract cleaning and adjustment. Ask people who sew whether they have the name of a repair person. Taking apart the machine and replugging the connection should be all of a 15 minute job.
Feb 23, 2013 | Husqvarna Designer I
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
Original designer I and the touch screen is frozen.
The front cover will have to be removed to access the componets to find the problem... it could be as simple as a loose connection or as complicated as having to replace the touch screen. Removing the front cover is not a simple task if you do not have experience in working on this machine. I would suggest it go in to an "authorized dealer.
May 15, 2010 | Husqvarna Designer I
Janome 300e touch screen not working
The screen has something stuck around the edges or its damaged, have you tried to touch all parts of the screen to see anything happens? If you need more help 612-270 2957
Jun 22, 2009 | Husqvarna Designer I
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
You probably have the old-style touch panel which is known to fail. Viking has a five year warranty on electronics but sometimes they will cover this particular part beyond the five years. If you find a sympathetic dealer you may be able to get the part for free. You will need to pay for the labor though.
Feb 05, 2009 | Husqvarna Designer I
Problems recalibrating Designer 1
switch on while holding in reverse & pivot buttons. release then press needle stop button. calibration marks will appear. set & restart.
Jun 27, 2008 | Husqvarna Designer I
Screen is frozen
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Dec 26, 2007 | Husqvarna Designer I
Sewing Machines Logo
397 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
