Question about Campbell Hausfeld Pressure Washer Gun - Electric/Gas Up To 2200 Psi - PW102400AJ
I can't get any water pressure out of the gun itself, it was working fine, then it just stopped. Any suggestions? Is there a way to take the gun apart and clean out any deposits that might have built up in the shaft?
    Sergeant:
  • 259 Answers
Yes you can take the gun apart it usually unscrews from the middle.
Posted on Mar 22, 2011
Motor is working but does not spraying the water and also cant remove main hose from both machine and trigger gun. what is the problem?
Hi Fahad:
I could be suspicious that the gun may be clogged.
If the hose and gun are pressurized the couplings should not be able to be dis-connected. The pressure should be released first by shutting the motor off and then squeezing the trigger to allow the water to drain.
May I suggest that you first try a different nozzle on the gun, and if it still won't work, a "dismantle and service" procedure would be the next step.
Mar 13, 2016 | Garden
Jet stops and water comes out of main unit
water usually only comes out of there if its hot or damaged. if water is hot its ok, check for temperature anomolies, if water is not hot replace temperature relief valve
Feb 27, 2014 | Garden
K3.86 The motor will not start. It starts for a few secons than stops. Does not products any power Thanks Jim
Dear Sir,
Normally when one closes the gun the machine stops. So you may have a blockage problem that is shutting the machine off. You may try to diusconnect the gun so that you run the machine without load. But..ALWAYS...with water being fed. Never run a power washer without water being fed. Without gun and water fed normally....your machine should continue working. If so you can attach the gun without the lance. If it works, you have a blocked nozzle in the lance. If so try with a very thin needle to clear the nozzel. Do not make the nozzel's hole bigger with cleaning, because then you lose power. Now these machines stop automatically by means of a control valve (Spill Valve). The spill valve when the gun is closed, pressure is created and the spill valve in turn will move to close the electricity by means of a micro switch. Spill valves give a lot of trouble if machine is left with soap in it, or if the machine is stored with pressure in it. NEVER STORE A POWER WASHER WITH PRESSURE IN IT.....always when finished working disconnect electricity, disconnect water and finally press the gun to release pressure. Well as I already said start by putting on machine without load. Then add the gun without lance so that you see that when you close the gun the machine stops....and when you open the gun machine starts again. All this without lance attached. Also in cases like these the Spill Valve sometimes gets jammed in the cutting off electricity position. Spill valves only need to be serviced with good silicon grease....but in doubt change the spill valve. If you open the machine the spill valve is located where you see 2 wires coming out. You should have special tools to remove and service/change the spill valve. Well hope you have a small idea from where to start.
Apr 19, 2011 | Karcher Garden
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Oct 03, 2009 | Karcher Garden
I have a karcher K3.98 pressure washer. The unit surges when I put the wand on and then it stops working. I tried cleaning the wand (didn't make any difference) I then tried another wand from my son's unit...
Dear davedulmage,
To see if the unit is OK....first you must switch it on without water and without high pressure hose and gun. If machinr works smoothly, try by attaching a water supply. Now run the pump with water coming out of the outlet. If also in this case all runs smooth, then attach high pressre hose with gun but without lance. Put on the machine with gun open(to reduce initial resistance) and when you see a clear flow of water coming out...close the gun. The machine should stop. In this case I am suspecting that when you open again the gun the machine will not work. So it seems that when pressure is built in the pump a fault is occuring in the Spill Valve or also called Control Valve. When the gun is closed and pressure built up, this spill valve contracts and switches the pump off. When the gun is opened, the spill valve extends, putting the machine on and closing a valve at the base of the spill valve. So in your case it seems that the spill valve needs to be renewed. A spill valve gets stuck by incorrect using of the pump. For example leaving the pump with pressure in it for a long time. Also it gets stuck by detergents and chemicals. Sometimes I lubricate Spill Valves with high quality silicon grease....but it is much more practical to change it. When a new spill valve is put in....always run the pump with no load. This by usiing the gun without lance or wands, resulting in low pressure. If all OK...add a lance or wand that you are sure it is good. One final thing....to get to this spill valve you must put apart the body and expose the pump. If you are not that good at doing this job...it is better done by a more knowledgeable person. But changing the spill valve is worth it....because it is cheaper than a new machine.
Regards,
Fulltech.
May 19, 2009 | Karcher Garden
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
Campbell Hausfeld Pressure Washer Gun - Electric/Gas Up To 2200 Psi - PW102400AJ Logo
230 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Steve
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
