Question about Rolex Watches
Do you have a Seapearl 600 quartz model with day/date
5 Suggested Answers
SOURCE: Unable to set the date on an ESQ Gentlemen's Quest Big date
l Have a E3675 with three small dials know one is seconds dont knkow what the other two are
Posted on Jan 27, 2009
SOURCE: Set hour minute on Omega Constellation Day Date (Quartz)
Found solution at: http://www.timefactors.com/omegacon.htm Regards, Joe
Posted on Jun 11, 2009
  • 2501 Answers
SOURCE: My Geneve watch, model
The stem (or crown) is sometimes screwed in to improve the water resistance of the watch. Try turning the crown anticlockwise before pulling it out.
It may be necessary to take the hour hand past midnight to get the date to change. This will be the case if there is only one "out" position.
If there are two "out" positions then one will be for the date and one for the time.
Posted on Jan 17, 2010
  • 4 Answers
SOURCE: how to set day and
Typically, you need to run the time around until the right day is up and the right time is set to am or pm. Then turn in the other stem position until the correct date shows up.
Posted on Jun 26, 2011
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Tip
TAG HEUER quartz watch with date manual.
Follow this link and download original TAG HEUER quartz watch with date manual: http://www.tagheuer.com/the-collection/link/men/quartz-watch/index.lbl?w=WJ1110.BA0570
on Feb 09, 2010 | Watches
How to set day and date on a Benrus quartz watch model # BN529? Has one stem with two pull out positions. The first position only changes date going only in direction.
Jun 26, 2011 | Watches
Rolex President Day-Date Men's Watch
Rolex, at one time, had a quartz (battery operated) watch. It was only manufactured in solid gold and was distinctive in style from other models. It is no longer being made. For all practical purposes, it you see a battery operated Rolex it is not genuine.
May 23, 2010 | Rolex Day-Date President 118239 Wristwatch
My Geneve watch, model "Seapearl" is only two months old. It keeps good time but the date is behind by 1 day. How do I adjust the date? I have tried to pull the stem but it will not move.
Jan 16, 2010 | Watches
Watches Logo
93 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
