Question about Uniden Bearcat Pro PRO510XL 40Channels Base CB Radio
My Uniden 200XLT is permenant L/O and will not scan but will search and wx works.
    New Friend:
If all channels are locked out, that normally happens if the battery is allowed to run completely down for awhile. If that's the problem, you should be able to turn the Lockout off on any channel using the L/O button. If it is simply that the L/O button isn't working and the other keys are still working as they should, the conductive material on back of the L/O key may have worn off. I do not know if those keyboards are still available or not. If not, I have seen 200XLTs on ebay for as little as $10. I have also repaired them by cutting a tiny circle of aluminum HVAC tape and sticking it to the back of the faiIed key. If you can elaborate a little more on exactly what's happening, I may be able to troubleshoot further.
Posted on Mar 04, 2015
  • 391 Answers
Hi to avail of the scan facility your squelch needs to be turned at about 1oclock this will enable the scan for you iff problem persists its best to leave to the pros
Posted on Mar 30, 2011
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Cannot get international channels
From the owners manual (Page 4, link below) Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same time to change channel modes from USA to INTERNATIONAL to CANADIAN.
-Steve
http://www.uniden.com/pdf/SOLARA%20DSC-BKom.pdf
Oct 12, 2013 | Uniden Solara DSC VHF Marine Radio
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
What does the key on the bottom row of keys as well as the other four buttons mean they are LIGHT, WX, L/ O, PRI
From your description, it sounds like your scanner is actually a BC60XLT-1, which is different from the BC60XLT. On the "dash one" the key with the key symbol is for locking and unlocking the keyboard to prevent accidental entries. Press and hold it to lock the keyboard (a key symbol will appear on the display); press and hold it again to unlock the keyboard for normal use. The LIGHT key will temporarily turn on the display backlight for night viewing. The WX key switches the scanner to monitoring of the NOAA weather channels. Pressing the WX button will result in scanning until the unit locks on to a weather channel/frequency that's in use of your area. Press the SCAN key to resume normal operation. Pressing L/O key will lockout whatever channel you are listening to. Pressing it again while stopped on that frequency will restore it to normal monitoring. Pressing PRI will set the selected channel/frequency for priority monitoring, causing the scanner to sample that frequency for activity every few seconds, and to lock onto it if activity is detected. Pressing the key again, while that channel is selected, will release the priority function.
For full information on the functions and capabilities of the scanner, as well as detailed information on how to program it, you can download and print the operating manual, free of charge, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Sep 17, 2010 | Uniden BC60XLT Handheld Scanner
How do i change my vhs from US to INT AS I CANT FIND MANUAL. IT THE SOLAR MODEL?
From page 4 of your owner's manual:
WX/ALERT/UIC - Press this key to listen to active NOAAWeather channels.
Press and hold this key for 2 seconds to place the radio into the Weather
Alert mode. Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same
CANADIAN.
Aug 14, 2010 | Uniden Solara Vhf Dsc Fixed Mount Radio
I am looking for a manual for a uniden bearcat scanner 210 xlt. Thanks
Uniden's website don't seem to list a 210XLT. Found a 220XLT manual at Uniden Australia, a 200XLT at Uniden U.S.
Uniden US scanner manual download page - check here.
Apr 13, 2009 | Office Equipment & Supplies
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Uniden Bearcat Pro PRO510XL 40Channels Base CB Radio Logo
112 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
