Question about Husqvarna 19.5hp 46" Yard Tractor
I accidentally switched battery cables from positive to negative and vice versa. My lawn tractor started for a second and now nothing. What might I have burn out?
3 Suggested Answers
  • 124 Answers
SOURCE: husqvarna lawn tractor stop running has battery
Does the engine turn over when you turn the key. If it does then it is mostly not getting fuel past the carb into the engine. If it does not turn over then it could be the switch or solenoid but it could also be a problem in your wiring system or a safety switch which is interrupting the ignition.
Posted on Sep 22, 2009
  • 1388 Answers
SOURCE: Husqvarna 48" Lawn Tractor:
The link below for details of wiring. Assuming good connections at the battery and ground to frame. Your unit uses lots of 12v power for charging, lights and the electric clutch (must have good charging system to run this mower). There is a fuse between the amp meter and starter solenoid. If the fuse is open, the meter will not show charge or discharge. No start or even click would indicate that one of the safety cut-out switches is not engaging (seat, break/clutch etc.). Easy to test switches with meter (refer to wiring details at link below). The charging system is easy to test with meter. Once you get the engine running, test for 28volts ac (3600rpm) from two wires at the regulator (two wires from ac alterator under the flywheel of the engine). Then look for 12 to 14 volts dc at the output side of regulator. Good luck with repair
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2011/HIUS2011_532440469.PDF.pdf
Posted on Jul 02, 2011
Bought a Toro Timecutter SS 4235 about a month ago. Mowed the lawn about 5 times. When I turned it off after the last mow it made a funny sound. When I went to start it today I got nothing. Checked the...
Could be your battery shorted install known good battery, make sure key off. Install positive cable then slap negative cable to negative post if no spark then install. Sit on tractor and try to start as usual if you have problems starter circuit probably starter bad. If not try engaging blades if problem, pto wire grounded or clutch winding bad. If everything OK then shorted battery.
Sep 22, 2017 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
19.5 hp twin craftsman serial number 917259560 turn key nothing happens battery new, switch uner seat in ok position
Check that the blades are not engaged. If they are not engaged and you still have nothing, check battery cables tight. Then check the starting solinoid.
If you have any questions on how to do this or other related, just reply.
Jul 13, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman model 917.255812 lawn tractor - was running fine, turned off to empty leaf catcher - got back on and it would not start - doesn't turnover at all. I have replaced the battery and...
Hello Pappy,
Sounds like it is the starter solenoid that is on the positive battery cable on the right side panel below the battery. Part # 146154. Jump the two main terminals with a screw driver and if the starter turns the engine that's your problem. Be sure to remove the negative battery cable when you go to change out the solenoid.
If this was helpful, please vote yes. Thank you!!
May 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I was jumping my 95 ford mustang when I accidentally put the negative cable on the positive post and vice versa. The cables starting smoking so I immediately turned the car off that I was jumping my...
there is not a fuse for just the speedo. Only possible fix is to remove the positive battery post for 30 minutes to reset the ecm/pcm. You probably fired the circuit though. Good luck.
May 19, 2011 | Ford Mustang Cars & Trucks
1994 Toyota 4 runner: I changed battery just fine; but can't get the fastener back in place.
I would make sure the fastener fits your battery and vice versa. Make sure it is not upside down or something like that. Is the replacement battery the same size as the old one? Battery REMOVAL & INSTALLATION NOTE: Refer to Section 1 for details on battery maintenance.
  1. Disconnect the negative battery cable from the terminal, then disconnect the positive cable. Special pliers and pullers are available to remove the clamps. Be careful of the many wires and fittings on and around the positive terminal. NOTE: To avoid sparks, always disconnect the negative cable first and reconnect it last.
  2. Unscrew and remove the battery hold down clamp.
  3. Remove the battery, being careful not to spill any of the acid. NOTE: Spilled acid can be neutralized with a baking soda and water solution. If you somehow get acid into your eyes, flush it out with lots of clean water and get to a doctor as quickly as possible.
  4. Clean the battery posts thoroughly before reinstalling or when installing a new one. A light coating of petroleum jelly or battery terminal spray protectant will help fight corrosion.
  5. Clean the cable clamps using the special tools or a wire brush, both inside and out.
  6. Install the battery, and the hold down clamp. Connect the positive and then the negative cable. Do not hammer them into place. The terminals should be coated with grease to prevent corrosion. CAUTION
    Make absolutely sure that the battery is connected properly before you turn on the ignition switch. Reversed polarity can burn out an alternator in a matter of seconds.
Jul 04, 2010 | 1993 Toyota 4Runner
Tried to jump start 94 chevy corvette and accidentally placed the negative cable on the positive terminal and vice versa. Got a new battery, but it only turns over. SYS flashing on dash screen. Help!
check to make sure no wires are melted apart. and also check fuses. espesially the main fuse. check the voltage from alternator to battery, it should be 14 to 14.3 when running. battery voltage should be about 13 volts when engine is off.
May 16, 2010 | 1994 Chevrolet Corvette
Clicking and takes a wile to turn over
The clicking you hear is the starter solenoid making and breaking connection and this can be cause by a tired battery or poor conductance between battery and starter.
You can have the battery load-tested at any auto parts chain store but if you know it should be OK, then your problem can be caused by corrosion at the battery terminals or at the other end of the heavy cables; the positive cable goes to the main starter terminal, the negative may go to the chassis and then the engine block or vice versa.
To clean these, ALWAYS disconnect the NEGATIVE terminal FIRST. Removing the positive first can result in accidentally getting your tool between there and any grounded metal; something you really don't want to do to the tool or battery terminal.
Good luck-
Feb 08, 2010 | 1999 GMC Suburban
How do i change the battery cables on my 92 explorer fwd 6cyl.
remove the negative cable first then the positive and vice versa when installing the new cables
Aug 15, 2009 | 1992 Ford Explorer
Starting wireing and selenoyd and switch
Red positive wire, goes from battery to switch (right side) then goes to solenoid. Black negative wire goes from battery to ground. Than goes to solenoid ground.
Jun 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 19.5hp 46" Yard Tractor Logo
116 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
