Question about Dryers
Ge dryer spinning counterclockwise? - Dryers
  • Marvin
    Marvin Mar 22, 2011
    It makes no differnece which way the dryer spins as long as it SPINS, RIGHT?
    Sergeant:
    Champion:
  • 202 Answers
Its a one way motor it can`t spin the other way
Posted on Mar 22, 2011
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
GE dryer turns on but doesn't spin
Probably nothing but a broken belt. Ge dryers can be tricky. Most of them cannot be accessed from the rear anymore. Lots of videos on youtube now that show how to replace a dryer belt on a GE dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 20, 2014 | General Electric GE 7 0 Cu Ft Super...
When pushing the start button the dryer makes a buzz sound but nothing happens. If the belt was broken I should hear the motor running. The dryer is 18 months old and gets normal use for a small family. I...
Most likely the motor. If you have a second set of hands, you can try and hand start it. Open the door, hold in the door switch (or tape it, if you don't have anyone to help), press the start button, and then grab one of the drum fins, and spin the drum counterclockwise and see if it takes off.
Oct 15, 2013 | GE GTDP300EMWS Dryer
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
My dryer when pushing start gives a hummimg sound and the drum of dryer only will spin counterclockwise now. Any suggestions of what is going on?
You Probably Need To Change The Motor. Or Check You Voltage Make Sure You Have 240 Volts At The Plug.
May 28, 2012 | Whirlpool Dryers
My dryer knob has broken again. Wich direction should I be turning the knob when choosing a drying cycle? I was told I was turning wrong direction.
GE dryers turn in the clockwise direction and if you turn in the counterclockwise direction you could break the stops off the switch.
Jun 20, 2011 | GE Dryers
I need the owners manual. I need to know if it makes a difference which direction you turn the dial when setting for drying time. Clockwise? counterclockwise?
Since you haven't stated a model # I can give you a generalization - that manual timers are designed to turn counterclockwise ONLY. Most will not even spin counterclockwise when you try.
If you pass by the setting - you should go around again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2010 | Dryers
Ge wwsr3090t2ww wont agitateor spin
This is a pop off type. and The timer seems to have gone bad as long as the motor is turning and the belt is not stretched.
Feb 10, 2009 | GE WDSR2080D Top Load Washer
Dryer drum won't spin
remove rear panel remove screws in blower housing ck for objects in blower ..if you still have dryer apart remove belt from motor pulley and try turning by hand
Nov 15, 2008 | Estate TEDS840JQ Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
Marvin
Marvin
