Question about SYMA Toys industrial Syma S026 Micro Chinook Cargo Transport 3 CH Indoor Ready to Fly RC Remote Control Helicopter
Once the battery charged in S026 heli. Its not taking off from the ground. But its moter is running. I got this from UK right now I am in India. I want this problem to be fixed
Syma S026 instructions
We have a free copy available on our website.
Free Syma Helicopter Manuals
Kind regards, Julian.
rccontrolfreak.co.uk
Mar 05, 2013 | SYMA Toys industrial Syma S026 Micro...
How to charge rc ignite helicopter
There is a male jack in the right side bottom of the remote. It looks like the end of a lap top charger only smaller. on the bottom of the heli there is a hole where it fits into. make sure it is in far enough, Not all the way! the heli must be off and the remote must be on. when it is charging the on-off light will blink. when it stops blinking it is charged. if it doesn't blink when you plug it into the heli try pushing the jack in a little farther. mine when in and stoped and i had to push just a little harder to seat it. Good Luck:)
Mar 04, 2012 | Toys
The helicopter does not fully charge
You mention the controller, new batteries are good for the controller, but you need to have your heli batteries to be charging correctly. If you get new heli batteries, then Check your charger, it is probably not putting out the right voltage.
e
Nov 19, 2011 | Toys
My Syma 107 will not lift off the ground. It lifts a little bit and thats it. Its only a week old.
r u charging from the controller? if so put luthium aa batterys in controller the ones you have in there now may not be giving a full charge, you r turning the controller on when charging heli right? wait for the chareer light to turn back to green from red will tell u charge is done. u must have a computer 2 have posted this so charge ur heli from computer wait 4 it 2 light up red (the usb plug) b sure heli is off when charging the little swith should b forward toward nose of heli if it still wont lift off after a good charge b sure the top part of the blades are tight on shaft, its the two screws just under the top blades 1 of the 2 must b tight on the shaft or it wont get enough power if it is slipping, if it still wont lift off u may have a bad li po battery never run it way down!! always stop flying when u c the heli start to not have enough power to hover, always stop and let batt cool dn then charge, then after charge try 2 wait 4 a little bit b 4 flying 2 let batt cool from charging, i know it is very hard 2 wait, hoppfully u have not fryed the battery if u still cant get it e mail me and i will help u get up and flying good luck the s 107 is my main bird i work on them 4 friends all the time if i had it 2 look @ u would b fly n n 5 mintues my e mail is pznuraz@yahoo.com
Jul 29, 2011 | SYMA Toys industrial New Syma S107 Mini...
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
It charged for 5 hours, and only flew 5 minutes
I'm afraid this is nothing unusual. Many helis run the same amount of time. Unless you have modified your battery setup you will be using nimh batteries and they are renowned for losing power and storage ability whilst not in use. You give almost no information so it's impossible to give any definite answers. How old is the battery? are you charging it with the correct charger? How fast did you run the heli? I ran two of the exact same helis only yesterday and I was lucky to get both of them off the ground three times before the batteries died and when Nimh die they just die very fast with little warning. Perhaps you could reply with more information as to the age of the battery etc as above. Just remember that batteries only have a limited life and with poor maintenance their lifecycle drops dramatically.
Dec 25, 2009 | Axial Syma 9086 Helicopter
SYMA Toys industrial Syma S026 Micro Chinook Cargo Transport 3 CH Indoor Ready to Fly RC Remote Control Helicopter Logo
20 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
