make sure the usb cable is properly connected and the driver is installed. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd. Make sure you install the driver properly and check the test print also .still if u fail check all this setting and follow this steps,1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction. Have a nice day and do not forget to rate please...!
With the Lexmark printers communication subsystem you MUST let the
driver ask for you to plug in the printer. DO NOT plug the printer into
the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
For the Lexmark 1270, go to www.lexmark.com and click on DRIVERS AND DOWNLOADS. Then use the DRIVER FINDER. In SEARCH BY MODEL, type in 1270 and you can choose a driver from there.
hello I want to install my printer lexmark x1270
please send me an email that how I can set up it
'i sent two emails
I need help please
hurry I do not have time to sit behind this stupid computer
The only way to setup the printer without the proper drivers would be to use windows add new printer. However windows does not have lexmark x1270 listed. You can dlownload the software from lexmark & install the software / drivers without using the cd. http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:537:0:0
You need to choose your version of windows to continue.
This next site will show you how to connect your x1270. http://www.lexmark.com/publications/eng/1200/index.html
Also listed is the user's guide manual.
Hope this can help you.
please vote
