Question about Gateway Md2419u ATI 99802481742 PC Laptop
My Gateway MD2419U laptop's "I"
  • 35 Answers
Hi this no spareparts for th key --you wanna buy anew or used keyboard =ithink price is 50 $
Posted on Mar 22, 2011
Gateway M6332 touchpad button doesn't work.
It is easier and better to get it repaired instead of repairing it yourself
Jan 06, 2013 | Gateway M-6332 Notebook
How to replace a video cable
In a Gateway M-7351u Notebook PC?
1) http://www.insidemylaptop.com/replace-broken-lcd-screen-gateway-m-series-laptop/
2) http://www.insidemylaptop.com/replace-keyboard-gateway-m-series-notebook/
Motherboard side of video cable, should be under the Switch Cover, (LED indicators, Power On button, speakers, etc), or under the Keyboard close to the Switch Cover.
Don't forget to remove ALL power. Remove the AC adapter (Charger), and Battery. (Use CARE. Wires going to Switch Cover. Do not cut them by accident, or pull on them when removing Switch Cover )
http://www.ebay.com/itm/GATEWAY-MC7310U-MD2614U-LCD-VIDEO-CABLE-DD0AJ2LC000-/390069940144
Regards,
joecoolvette
Oct 24, 2012 | Gateway M-7351u Notebook
Do I need to purchase the service plan/pak from Gateway in order to buy a recovery disk
Wow, why not just make sure you have access to an Operating System Disc that is the same as your operating system. Then periodically copy your My Documents folder to a USB Flash Drive or to an external drive for backup purposes. Most times those Recovery Discs don't work. The only good recovery that works most times is when the manufacturer burns the partition on the hard drive.
May 02, 2012 | Gateway Computers & Internet
Gateway md2419u needs recovery disk for windows 7
I remember seeing your other post about this same request for help and you mentioned that Gateway wanted $149 to help you out.
Take the computer to a local repair shop if you need the operating system reinstalled. This should not cost more than $60 to install the same version of windows that was on your computer. Just make sure that the Certificate of Authentication (COA) sticker on the bottom of the laptop is legible so that they can know which operating system you had and what the key code (a series of five digits and letters) is.
May 02, 2012 | Gateway Md2419u ATI 99802481742 PC Laptop
Im trying to turn the light off of my laptop keyboard. the battery drains within a hour and im hoping this helps.its a gateway notebook MD2419u
It will help !
Also, Right-click the little battery on your taskbar, and select Energy Save Mode
This will help alot, but degreases speed.
Jun 21, 2011 | Gateway Md2419u ATI 99802481742 PC Laptop
My Gateway MD2419U laptop will not charge after it reaches 87%. It says "0% remaining" when unplugged and "0% available (plugged in, not charging)" when plugged in. Why does this...
Its an issue with the BIOS code.
Updating the BIOS will fix the issue.
Update it to Version 9A30a for Windows 7 and Version 9A10h for Windows Vista.
You can find the BIOS update on the Gateway website.
Dec 09, 2010 | Gateway Md2419u ATI 99802481742 PC Laptop
Unable to remove Gateway m680 Laptop LCD Bezel
I would try just using a little bit more force (not too much!) the bezel will have clips around it to keep it in place along with the screws under the rubber protectors. Also make sure that the bezel doesn't hook in to the hinge cover in any way, as this will prevent it from coming off properly. If it does then pop the hinge covers off before continuing.
Aug 04, 2009 | Gateway Computers & Internet
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Broken key on my gateway laptop
key on a laptop's keyboard cannot be fixex once its broken
but the whole keypad needs to be replaced
you can call gateway ... if your system is under waranty you even don't have to pay for the keyboard.
Jun 10, 2008 | Computers & Internet
Keyboard
lay the screen all the way back ,and with small screw driver take off hinge coverings which should open up entire uppper key board assembly,then unscrew small screws lift keyboard and remember to detach scuzzy cable for key board. you done
reverse for reinstalation .. la la linda
Apr 26, 2008 | Computers & Internet
Gateway Md2419u ATI 99802481742 PC Laptop Logo
272 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
