Question about Microwave Ovens
Most of the time while putting stove into the bake setting it will trip the breaker
  • 604 Answers
You need to plug your unit into a power outlet that is fused higher (at least 15 amps) or if the breaker is 15 amps, you may just need to replace the breaker (they do wear out).
Posted on Mar 22, 2011
When it is running the lights flicker or go dimmer or trips a breaker.
you have too much wattage on the same circuit. microwaves draw 1000-1100 watts typically, something else in on the same circuit drawing another 700+watts and tripping the circuit breaker. lights, refrigerator, stove, fan, hair dryer, etc, etc. if you turn everything else off and you have the same issue, then you may have an electrical issue with your wiring and it could be a potential shorting/fire issue. be cautious, be smart.
Jul 23, 2015 | Microwave Ovens
Freestanding stove (range) keeps tripping breaker when oven is used or two burners are used
Is this a new installation?? It sounds like the circuit breaker is under rated for this unit.
Nov 03, 2013 | Panasonic NN-H965 Microwave Oven
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
When using the oven portion of the microwave oven it continues to trip the circuit the microwave is alone on a 20amp circuit .When I microwave it doesn't trip at all.Is it possible to move up to a 30 or 50...
If the breaker is an earth leakage type, it is possibly an earth leak problem which could be caused by insulation breakdown on the heater inside the microwave.
I would consult an aporved electrician for advice.
Jan 04, 2011 | Microwave Ovens
During the cooking for our Christmas dinner the temperature started declining from the 350 degrees to 280 degrees. We tried the top burner to make sure the stovetop was working and the whole thing shut...
Hi Jane,
Ouch! Sorry about the Christmas dinner. I sounds as though the circuit breaker tripped.
First, find the circuit breaker panel.
1 Check to see if a breaker has tripped. These breakers are double sided because stoves are
240 volt appliances, like the water heater or the house heater. There is a bar that connects
two single breakers together. The breaker will be slightly off center to the other breakers if it is tripped.
2 If it HAS tripped DON'T TURN IT ON YET
3 Go back to the stove and plug it in.
4 Turn on a top burner(not the one that may have tripped the breaker) preferably one that you know works that you don't use very much.
5 Go back into the garage and turn on the breaker.
6 If it goes on OK go back to the kitchen. You have done the first diagnostic test.
7 Check the burner to see if it is getting hot. If it is, turn it to high and then turn on the burner that blew the breaker in the first place. See if it blows the breaker again. If it does not. Turn on all of the burners that you know work. You have now done several Diagnostic Steps that are important.
8 If one of the burners trips the breaker, you have one of the culprets. If not, GREAT.
9 Shut off all of the burners
10 DO NOT TURN ON THE OVEN
11 Open the oven door and look very carefully with a flashlight at the bottom bake heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced.
12 There is one other rare possibility, but it would not have blown the breaker. Many ovens have clock baking timers. These timers will, shut down the oven. If someone adjusted the timer and didn't turn the knobs in the exact right position. It will ruin the party shutting down the oven at the worst time. But it won't shut the stove top burners down.
IF YOU HAVE FUSES INSTEAD OF BREAKERS
If you have fuses instead of circuit breakers, Find several of the large cylinder shaped fuses to conduct the diagnostic tests I suggest. They are usually available at home depot.
RARE PROBLEM
One last but very rare occurence with breakers is their specifications sometimes change over a long period of time. If that is the case, they will trip and lower and lower overload levels. Simply Replace.
I hope this helps,
Good Luck
Best Regards,
Mark
Dec 29, 2010 | Microwave Ovens
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
I forgot to turn off my 5HA-196X after a pizza-bake operation. Next day the breaker was tripped and I reset it. On subsequently, turning on the oven and setting it to bake there was a loud pop and spark....
Hey this is tbirdfan1 AGAIN I GOT DISCONNECTED I HAVE THE PICTS
I THINK THAT THE PARTTHAT BLEW IS PART OF THE WHITE BOX THAT I SEEN IN THE PICT BUT CAN YOU REENTER THE CHAT
Nov 30, 2009 | Microwave Ovens
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Stove lights
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
