Question about Duravit Home
I have a motion sensor which operates the lights on my bathromm cabinet, and this appears to have burned out. The part is called a smart power switch 1-550 isc (relais switch 0-550VA integrated sensor control). The part appeas to be made in Germany. I have searched for the part on the internet without success.Any ideas where I can source one? Thanks.
    New Friend:
Wird das Bauteil noch gebraucht? Ich habe noch welche auf Lager.
Einfach eine Mail an Info@PG-Dienstleistungen.de da kann alles weitere besprochen werden
Posted on Nov 14, 2016
Me too, Duravit supplier quoted GBP70 for a replacement which is a rip off, anyone have a solution for this or a generic component that does the job?
Posted on Jun 12, 2014
  • Peter Pope
    Peter Pope Nov 06, 2014
    Ours failed within a couple of years and looked then but couldn't find one. However, don't want to pay £70!!
    New Friend:
I have the same problem - do you ever find somewhere to buy one?
Posted on Mar 22, 2013
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
I have an ADT security system, the DCS alarm panel lcd5501z panel bypass motion sensors will not reset. The door and window sensors work fine when the alarm is set. but the interior motion sensors stay...
I would power down the main cabinet for 1 min. And unplug the battery in the cabinet. Most of the time this cabinet ( panel ) is located in a closet and contains the main brains of the system. Sometimes there is also a reset on the motion but when used, it can put the motion in test mode. You can also check the batteries in the motion ( if its wireless) The first thing I would do is power down everything and disconnect the battery. This resets and works 90% of the time. You might need the key to get into the box.
Sep 06, 2013 | DSC Power Series Lcd5501z 5501z Fixed Msg...
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
I just replaced the 2 light switches in bathroom they still dont work
you need the critic checked,a om meeter is need
Apr 21, 2012 | Home
Manual for EML Series ES100T 3 light motion sensor
The bulbs DO burn out occasionally, even after a short time. There are no markings on them that I can see. I have a unit. If it is the same as yours, it is a 100W 120v 8mm(G8 or GY8) Halogen (bi-pin). They also come in 35, 50, and 75W versions, if you don't need as much light.
Nov 16, 2011 | Cars & Trucks
I have a cooper 6107 motion sensing 3 way wall swithch and I am using it to replace a three way non motion sensing switch. I have it wired correctly, green to ground, black to common, and the red and brown...
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Cooper Wiring Devices Motion Sensing...
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
I'm trying to install two motion sensor switches in my hallway and do not understand instuctions one light works and the other one doesn't only on and off.
typically the wiring in halways are a 'three-way' method. this means that one switch is provided the power and will switch this power between to wires 'travelers' to the other swtich. the other switch will be a three way switch as well, but instead of receiving power on one leg and switching it between the other two, it takes the other to and you select which one you get power from and the power continues to the light. Almost all of the motion sensing light switches are not 3 way. so you will need to either only put the sensor on one end and wire all the legs together on the other end (this would act as a regular light switch) or find somewhere that has the 3 way motion switch
Jun 27, 2010 | Cooper Wiring Devices Motion Sensing...
Home Logo
1,355 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
