Question about Little Giant Plumbing
I have a Little Giant submersible pump Model # 6E-CIA-SFS It has been in a sump basin for about a year. During the last rain, the basin filled up but the pump did not come on until I move the pump a little. It then pumped the water out and stopped. The basin filled again without the pump coming on. I pulled it our and checked it and it appears to work ok. It appears to work fine when I shake it abit but the float does not seen to have the ability to turn the pump on when the basin fills unless it gets moved. Is the micro switch bad?
    Top Expert:
  • Little Giant Master
  • 16,317 Answers
Use a meter to test the float switch
Posted on May 08, 2017
    Top Expert:
  • 45,960 Answers
The float switch is binding
2 Suggested Answers
  • 19 Answers
SOURCE: 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord : my little giant punp 10-cia has water in the main ...
Nope, not a good thing
Posted on May 18, 2010
Pump stays on with no water or obstructions
When you gently lift and lower the float, do you hear a "click"? If not the switch has failed and must be replaced or another method of controlling the pump must be installed.
Oct 13, 2012 | Little Giant 6en-cia-sfs 506630 1/3 Hp...
Little giant pump stays on with no water no debri till thermal turns it off
http://www.plumbersurplus.com/pdf/03303.pdf
According to above documentation, CIA model has a diaphragm that actuates the switch to turn it off and on. If the vents are plugged with trash it won't work. If the diaphragm has failed it could have water in the switch works. Either way you need to take the switch mechanism apart and clean and inspect it. Hopefully it is just gummed up with gunk from what ever you are pumping and a good cleaning will make it work again. You can also check the switch while you have it apart, should "click" when actuated. Be gentle, this stuff is fragile! Be safe. Remove all power before you start!!!
Oct 13, 2012 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
10E-CIA-sfs, Impeller needs a push to get started. Any suggestions?
Sorry to tell you this but youre going to need to get a new one.
Try a place called "harbor freight" think you might like the prices as well as the fact they ship it really fast.
Just take a look at the online cat.
Good luck,Gary
Sep 23, 2011 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
I have a Little Giant 6CIA submersible pump for about 3 years now, used once an in a trap in the basement waiting for a flood. Tried to test it today submersed and it would not work, banged it around a...
This pump works off of a pressure switch. You can remove the cover on the switch located on the side of the pump.You can either buy a switch repair kit, or you can open it up and take a look and see if the diaphragm is sticking. If you remove and clean the parts, you may have some success. Or, just buy the switch repair kit from your local Little Giant dealer. Good luck!
May 02, 2017 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
My sunk pump machine keeps running since last night. Is that a problem?
Check your float it may be stuck causing the pump to keep running.
Jun 10, 2010 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Plumbing Logo
122 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
