Question about True 598-TSSU7218 SandwichSalad Food Prep Table 72 38 Long 3 Doors 18 Pans
True tssu 72-18 is freezing the food. we replaced the thermostat and still freezing. any suggestions?
    Problem Solver:
  • 7 Answers
Did you make sure that you installed the end of the coil wire into the evaporator, it should go in about 8 inches at least, if you did that and have the correct thermostat, the make sure your fans are working. Miles
Posted on Jun 28, 2011
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
Coils freezing over
You will need to replace the defrost thermostat on the coils.
Dec 07, 2012 | True TSSU-48-12 Refrigerator Commercial
The True brand commercial refrigerator at my job is entirely too cold. How do I adjust the temp? Beer is exploding!
You will need to adjust the thermostat.
The thermostat will be hidden at the bottom back of the fridge near the compressor.
You may need a screw a flat blade driver driver to adjust the themostat
Apr 01, 2011 | True TSSU-48-12 Refrigerator Commercial
The fridge to begin with was extremely cold sometimes freezing the food a little even though it was on the lowest setting. 2 months later it has changed and now i have it on the coldest setting and though...
The symptoms are consistent with a bad thermostat. Start with being sure fans Inside and at the Compressor are running and if so replace the thermostat, if the unit still malfunctions, you'd need a refrigeration tech. That altitude won't make any difference. The Salad top units are just fine up to 7000 feet ASL no problem.
Jan 07, 2018 | True TSSU-48-12 Refrigerator Commercial
Compressor runs continuously freesing foods. Thermostat?
Yes for sure it is the thermostat but whether the unit has failed or if the controller is faulty or a wirelink had cut off is to be found out with a detailed check.
Look from the controller and see the sensor, if intact and at lower settign of temperature the compressor does not cut off, the thermostat is faulty.
Sep 18, 2010 | True TSSU-48-12 Refrigerator Commercial
TRUE Salad Unit freezing food/compressor will not cycle properly
Double check to see that you do have in fact, the correct thermostat. I have found a chart that shows that the differential is all over the board. There is a way to adjust these thermostats but is very time consuming and if you are not a refrigeration tech, you may struggle with the procedure.
https://www.truemfg.com/Support/Resource-Library
Mar 25, 2017 | True 598-TSSU7218 SandwichSalad Food Prep...
The fridge freeze the food
The thermostat is probably stuck closed and bad. A good replacement would be a Ranco A12-1560. If its not the thermostat there may be a stuck relay on newer modes coolers.
Nov 05, 2009 | True GEM-23
Open Questions:
See all True 598-TSSU7218 SandwichSalad Food Prep Table 72 Questions
True 598-TSSU7218 SandwichSalad Food Prep Table 72 38 Long 3 Doors 18 Pans Logo
454 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
