Question about Dewalt 3/8" Electric Drill D21009
I need to remove the chuck on my dewalt keyless chuck and don''t know how
  • 2,176 Answers
Go to the tip section under my handle and there are detailed instructions that will work with your drill. If you have a problem finding them let me know.
Posted on Mar 23, 2011
Tool piece stuck in chuck, unable to unlock it. Can you help
I would suggest contacting one of our Factory Service centers so we can take a look at it. Please see the link provided. DEWALT com
Mar 16, 2015 | Dewalt DC759CA 18-Volt Compact...
Chuck keyless removal
drill it out with a drill bit so that you are removing the head of the screw. this will work i have done it many times.
Aug 13, 2013 | Dewalt DC930KA Heavy Duty Xrp 14.4V...
Does a Dewalt 106 have a set screw?
Dewalt's DW106 does not have a set screw inside the keyless chuck to hold it on. This means the chuck was put on with enough lok-tite and torque to keep it on under most circumstances so getting it off will not be easy. If you're using the allen wrench-in-the-chuck method, give it a good firm whack until it breaks free.
Feb 14, 2012 | Dewalt Drills
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
How do I remove the screw holding the keyless chuck. Dewalt cordless 18v hammerdrill, I know it's reverse thread but it still will not come out. Is there a locking mechanism?
sometimes I have had to use an impact tool to shock the screw loose, what you might try is to tighten the chuck more and then remove. there is no locking mechanism that I know about. also I would recommend going to Dewaltservicenet.com and downloading a manual/breakdown for this before starting.
May 06, 2010 | Dewalt DW999K 7/8" Cordless SDS Rotary...
How can I disassemble a Dewalt keyless cordless drill chuck? I mean take it apart, not just remove it.
depending on the chuck it would take special fixtures to press apart, and unless you are very good with tools you would damage it beyond repair. I have never taken a keyless apart and tried to repair and put together, I have on the other hand done the same with the keyed chucks.
Dec 13, 2009 | Dewalt Drills
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 3/8" Electric Drill D21009 Logo
161 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
