Hello: I have a Denon avr 1909 that just started acting up. I was watching tv last night (HD Satellite) and the receiver started cycling though the different sound selections, then froze on 5 channel stereo and now we get no sound. Tried the reset option and that did not work either.
  • lori_a_sokol Mar 22, 2011
    Thank you for this information. It will be valuable when I take the unit in for repair.
    President:
  • 2,047 Answers
The symptoms described above are signs of a system failure which could have been caused by a variety of factors top of which is an electrical surge.The issue of being frozen on a channel is because the surge might have burnt up some components in the receiver thereby making it incapable of performing the function of channel change and also the sound ic would have been burnt also thereby the inability to produce sound.
Although there is a probability that the video ic could be partly damaged so if you refer the unit back to its supplier ensure to get them fix that as well.
Hope this solution has been helpful?
Posted on Mar 22, 2011
Denon avr-1909 has sound but no video, tried everything!!
Denon requires that you assign video to specific ports. HDMI, RCA or any other- you have to select which type and which port and you will get video.
Oct 22, 2013 | Denon AVR-1909 Receiver
I have a denon receiver avr 1909 and the remote control volume button do not work. A new remote control for this receiver is available?
If you mean a replacement, then I would contact Denon they should be able to tell you where and who can supply one. Generally replacement remotes are very expensive. So you might want to consider a universal one.
Aug 04, 2013 | Denon AVR-1909 Receiver
Just bought a 46" Samsung
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
This is a site where you can download a manual. I'm not familiar with Denen however, you should be able to go out of satellite receiver(HDMI) to your receiver input(tv/sat) then to your HDMI input on tv. Your receiver might show video and sound through another port of receivers options, ie; video 1, video 2, etc. Check all putput options for your picture and sound. Hope this helps.
Mar 04, 2011 | Denon AVR588 Receiver
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
I need reset DENON RC-1099 in begin state
Entering a new remote code will automatically erase the existing code for the device it is currently operating.
The remote for Denon devices is 111.
http://www.usa.denon.com/AVR-1909-OM_E_004.pdf
Dec 13, 2009 | Denon AVR-1909 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
361 people viewed this question
 Grubhead
Grubhead
