How do you reload staples in a Bates 213hd heavy duty stapler and what staples does it take
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
SOURCE: instructions on how to load a swingline heavy duty
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Posted on Aug 19, 2010
  • 10 Answers
SOURCE: I have tried to reload
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Posted on May 04, 2011
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here:
ACE STAPLE Quality Tradition for Over 50 Years
It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
Dec 02, 2015 | Heavy Duty Tools & Hardware - Others
How do you fix staple jam?
You may have to open up the stapler to expose the loading area then look for staples (or staple fragments) jamming the nose. It may be necessary to resort to pliers to remove the bits.
Aug 09, 2014 | Bates Power Arm Extra Heavy Duty Stapler...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
What size staples for a Cobra heavy Duty stapler?
Take it to home depot or lowes, they will sell you the right ones.
Feb 22, 2011 | Arrow Fastener 8000 Cobra Heavy-Duty...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Instructions on how to load a swingline heavy duty stapler.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Oct 06, 2008 | Stanley Heavy Duty Stapler, Cast Aluminum...
1,623 people viewed this question
k24674
jasbo
jasbo
