Question about Kenmore Elite 45986 Front Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
    Sergeant:
    Champion:
  • 202 Answers
Does it drain out all the water? after it stops or is there still water sitting in the tub?
Posted on Mar 22, 2011
I have the same problem it stops spinning during final spin cycle. The water is fully drained
Posted on Oct 01, 2011
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Posted on Dec 13, 2007
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Machine filled up, did the wash cycle but has completely stopped when it should drain. If I reset it, it will spin again, but again stops at the drain cycle. Help?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 24, 2011 | Washing Machines
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite 45986 Front Load Washer Logo
894 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
