Question about Husqvarna Operator's Manual 365 372xp Husky Chain Saw
Husqvarna 365 leaks chain oil from behind the clutch what 's the solution?
SOURCE: husqvarna chain saw oiler
Hi!
Oil pump mechanism is broken or the oil exit is clogged
Mark
Posted on Oct 24, 2008
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 345 leaks (over uses)chain oil
An IPL (exploded parts list) for your saw can found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit produced by Husky that week
The manual and IPL list no way to change oiler output. Your manual (page 16) says
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer." HTH
Lou
One question - are you using bar oil? It is thicker and stickier than most oils.
Posted on Oct 07, 2009
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
Replacing oil pump on Husqvarna 257
The oil pump is behind the clutch. You will see 3 bolts holding the pump in place. Some pumps must use the M5 screws in the 180 degree extractor holes. There is also 2 screwdriver slots you can use to pry out the pump is needed. If the pump lifts out, you are good to go.
May 23, 2014 | Husqvarna Garden
Husqvarna bar oil leak? I have a Husqvarna 55 Rancher. After it has been sitting for a while, there is a puddle of bar oil underneath it. After removing the bar and chain, then the clutch and starter...
There is always going to be some oil under the saw, the pump is a constent loss system, oil onto the bar and chain and away, there is a lot of areas in the crankcase and chain brake for oil to get caught and drip out once the machine is set down, if the oil loss is not excesive i would say yjere is nothing wrong here.
Mar 08, 2013 | Garden
Husqvarna chainsaw 450 oil leak
The 450 has a very simple non adjustable pump, it sits through a black rubber pick up/delivery pipe, they are quite prone to leaking where the pipe sits up against the crankcase, the part no. of the pipe is 544084201, changing this will help, you can also try using instant gasket to seal it, you will need to remove the clutch , sprocket, and pump plate to get acsess to it.
Oct 19, 2012 | Husqvarna 450 e-series 18" Chain Saw
Husky model 36, 16 in. bar, over oiling, non adjustable pump, will pump out a full tank of oil on about 3/4 tank of fuel, everything is spotless and dont have a clue on how to fix it.
The biggest problem with oiling on this machine was always under oiling, the pump is a fixed capacity so it should be impossible to over oil, it is more likley leaking from around the oil pump pick up and delivery hoses, or from the oil tank breather.If all is ok there then it is going to be a replacment pump.
May 11, 2011 | Husqvarna Operator's Manual 365 372xp ...
How much oil do you have to mix with fuel for a Husqvarna 365 special chainsaw?
50:1 is the fuel to oil ratio. Most oil bottles have dispenser guides for a gallon of fuel. Be sure to use a modern synthetic saw oil and fresh gas. Shake the container thoroughly each time just before adding fuel to the tank to prevent oil starvation. Hope this helps!
Nov 13, 2010 | Husqvarna Operator's Manual 365 372xp ...
How to install a new tension screw on a husqavarna 365
I have never done this but with the IPL as a guide it looks pretty simple.
Use care; it is easy to trigger the chain brake and is most difficult to reset with the cover off the saw.
Remove the clutch cover (brake off)
Husqvarna 365 IPL example (may not be your saw)
http://weborder.husqvarna.com/order_static/doc/usa/1999/I99000/I9901064.PDF
Detail A (clutch cover)
remove 2 each - 503 21 28-10* screws
remove 537 01 68-01, all parts now accessible.
Find your IPL here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
06 1500198
00198 = 198th unit Husky produced that week
GL
Lou
Nov 25, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
Nov 30, 2008 | Husqvarna Chain Saw 20" Bar
Is there a bar oil adjustment on my 36 cc husqvarna chain saw. Where might is be? Cheers paul
If there is one it'll be underneath the saw just behind the clutch cover/side plate. Though some of the smaller cc / hobby saws don't have an oil adjustment screw. happy hunting
Jun 29, 2008 | Husqvarna Husky 165
Husqvarna Operator's Manual 365 372xp   Husky Chain Saw Logo
723 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
