Question about KitchenAid Refrigerators
My kitchenaid fridge does not get ask cold as it has in the pass The freezer is cold but will not make ice cubes and i have it the highest setting.The fridge is cold but not as cold as before.I have clean under the fridge at the front and back with the vacuum.My guess is temp censer or defrost timer. not sure.The model number isKBRS22KGT14 and the serial number is ECK4402293.
  • KitchenAid Master
  • 1,769 Answers
Is the condenser fan and evaporator fan working? Is there frost build up on inside back wall of freezer? Either fan nor working would affect the cooling capacity. If there is frost in freezer, you have one or more defrost components (timer, heater, thermostat) bad.
Posted on Sep 02, 2017
  • 311 Answers
SOURCE: KitchenAid fridge clicks every 5 min or so.
Compressor relay is bad and needs replacing. Easily obtained as a generic part from any appl part supply. Unplug unit until fixed as it will not work anyway. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
SOURCE: freezer not getting cold
Call local Repair shop, No Fix possible, leak in the coils, can't repair.
buying new fridge.
Posted on Mar 23, 2009
jmgldsmth
  • 2005 Answers
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Posted on May 04, 2009
  • 16 Answers
SOURCE: The freezer and fridge keep defrosting
ck the defrost timer .that can cause your problem
Posted on May 13, 2009
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
Posted on May 28, 2009
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
Fridge not cold enough and freezer not producing ice cubes
how does any tradesman(person) know how much its gonna cost before they even look at it.....
i would suggest you call a small,family run,electrical shop.
they have a reputation to uphold......
Jul 21, 2010 | Daewoo Refrigerators
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not getting cold
buying new fridge.
Mar 22, 2009 | KitchenAid Architect® Series II KBRS22KT...
I have to make a freezer for a project that can prevent an ice cube from melting. i cant use a ice pack and i can only use a normal sized ice cube
a thermalcouple is a device that is wires of two different materials usually nickel and iron. when the junctions are at different temps, a small current passes and this effect is often used to measure temperature.
the reverse effect is that if a current is passed thro from an external source, one junction goes cold and the other goes hot.
it is possible to make as fridge using this effect.
Sep 07, 2008 | Refrigerators
The freezer is too cold.the highest temp. is 8.we can't go any higher. Our ice cream is so cold we can't scoop it out. we have an RB215LASH bottom freezer.
The fridge (on/off) is actually regulated by the thermostat in the refrigerator section. If the door leaks, it will force the compressor on too often. Otherwise, there is a port where the cold air is delivered (near ice cubes) -try (partially) blocking it with tape
Apr 01, 2008 | Samsung RB215LASH
Kitchenaid 8-yr old fridge wanting to upgrade icemaker
Check out this site - it gives a toll-free number to call to ask for exactly what you want. Unfortunately I have not been able to find any alternative ice makers advertised or discussed, but speak direct to frigidaire and they will keep you up to date on any new products. http://frigidaire.stores.yahoo.net/
Feb 25, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
