Question about Samsung BD-P1590 Blu-Ray Player
BD-P1590 will only show a black screen. I've tried unplugging it, switching out HDMI cables and still get nothing...not even the basic menu with the Netflix, pandora, youtube, blockbuster options. Tried updating the firmware from Samsung's website via USB but it won't let me as I'm only getting a black screen. Worked fine last night watching Blu-Ray Season 1 White Collar. Thougts?
  • 643 Answers
Probably needs latest firmware download. connect to internet and update.
Posted on Mar 22, 2011
Mitsubishi wd-60737 HDMI port 1 connected to cablebox. Screen is black and no sound. Cablebox is on, all cables connnected correctly and was previously working. Nothing new was done.
have you tried resetting your cable box? you can do this usually by either holding its power button in until all 3 lights light up, or by unplugging it from power , wait @ 30 seconds & plug back in .
Feb 07, 2015 | Mitsubishi Televison & Video
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
My PS 3 comes on but no display on the TV. I've
Stupid question i know ,buut, have you pressed AV on your TV remote !!
Jul 16, 2012 | Sony Playstation 3 (PS3) Console
I'm trying to program my Scientific Atlanta (Cox cable) remote to control my BD-P1590 BluRay player, but I can't find the correct 4-digit code. Can you help?
I will need the model of the Scientific Atlanta remote to try to locate a 4 digit code for you.
You can also go to the Samsung website and search their codes list. I will need a reply to further assist you. If I find the code I will post it here for you.
Mar 26, 2010 | Samsung BD-P1590 Blu-Ray Player
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Feb 07, 2010 | Samsung BD-P1600 Blu-ray Disc Player
My HDMI connection does not work with Blu Ray DVD player. I have tried a Sony (BDP - BX2 ) model and Samsung (BD-P1590). It could not even display the Home screen for the Sony. The Samsung played for 1 day...
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Dec 30, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Samsung BD-P1590 Blu-Ray Player Logo
259 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
