Question about ITT Jabsco Manual Marine Toilet Compact Manual Marine Toilet
Hi, please help i recently replaced all seals and gaskets in my jabsco compact marine toilet, it worked well for two weeks when all of a sudden it would no longer empty the bowl. It pumps water in easily but when empty is selected, the handle becomes spongy on the way down and would not empty the bowl. If the handle is pushed down slowly it will lift on its own once your hand is off. I have checked seacock and all outlet pipes as well as joker valve which is brand new for blockages, they are all clear. your advise would greatly be appreciated
    Sergeant:
  • 298 Answers
Hi
I don't specifically know your model of marine toilet but with my Baby Blake I have known the joker valve turn itself inside out (I think due to someone forgetting to open one of the seacocks) which meant that very little would pass out through it.
Posted on Mar 23, 2011
Jabsco toilet fails to fill
Was the toilet "Winterized" last fall? If so, have you assured that any plug in the clean water intake has been removed? If NOT -- are you sure the pump has not been frozen and internally damaged by ice? The pump is a simple device which rarely fail unless its inlet is blocked, or the pump seals or body are damaged - usually by freezing.
May 10, 2014 | Jabsco 29120 2000 Marine Manual Marine...
Toilet will not hold water, runs out as fast as you fill
where you press the pedel at the base of the loo the rotating valve has a seal , check for trapped dirt or damaged seal ! good hunting and wear gloves ! lol
Mar 04, 2014 | Jabsco 29120 2000 Marine Manual Marine...
Jabsco model 37010-0090 electric head. sometimes no motor run or flush when button pressed. By turning slotted shaft on end of motor , button then activates motor and flushes.
Sounds like the motor commutator and brushes need some attention. Not a difficult job if you have been there before but it can be tricky for a novice.
Oct 14, 2013 | ITT Jabsco Manual Marine Toilet Compact...
Need wiring diagram for jabsco 135 searchlight
I have an older unit, but this might help...
Thick Black wire is Earth or Ground
Thick Orange wire is Spotlight feed +
Thick Grey Wire is Flood feed +
Green and brown wires are motor up/down
Yellow and Blue are motor Left and right.
Sep 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
Jabsco 146sl repair
I am looking for a manual for a jabsco 60080-0012?
Jan 19, 2012 | Jabsco 60080 0012 Marine 146sl Remote...
Toilet backs up after use. even when holding tank is empty. we only use fresh water to flush from shower nozzle. toilet is fairly new replaced by original owner.
The system does not work, as you describe, you MUST use the unit's pump lever as the intake and removal are part of it's function. Use sea water to flush, the system is designed for that.
Jan 30, 2011 | ITT Jabsco Manual Marine Toilet Compact...
ITT Jabsco Manual Marine Toilet Compact Manual Marine Toilet Logo
393 people viewed this question
Top ITT Jabsco Boating Experts
Mike
Steve
Steve
Richard Marshall
Level 1 Expert
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
