SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
SOURCE: Siemens Gigaset C1 telephone
Solution not found, but putting it down to the age of the apparatus.
Thank you for getting in touch.
when someone trys to call the phone says please dial the desired number
SOURCE: Gigaset AL140/AL145. base phone 1 working
Put the other other hand sets on the base phone charger for 10 minutes and pin will be 0000...
SOURCE: Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
