Thompson 32WF401. The TV will no longer turn on. When in standby the red light is on. When you push a channel button on the remote to switch the TV on the light changes to amber for a second, the TV clicks and then the light returns to red. The red light then does three flashes followed by five flashes (I assume some kind of fault code). The flashes repeat 3 and 5 several times. Please help.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: tv won't turn on. power indicator light comes on then goes off after about three seconds, then retries twice more then locks out.
That is what these sets will try to do if the power supply detects a short. The set will try three times to come on then shut down again till you pull the plug or press the power again. It is not really a diagnostic code. Most likly your problem is the horizontal output transistor and or the flyback transformer. Very common problem for this set. good Luck Please do not forget to rate this thread.
Posted on Dec 15, 2006
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
  • 54 Answers
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
maam\sir,,,i think theres something wrong with its power supply,,,kindly chect the power supply section of your tv,,,thnksss and hope to help you,,,!!
Posted on Jan 29, 2008
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
The problem is the power supply components over heating. The power supply is on the back side right hand. supply extra cooling via a fan and it will stop shutting down. This is just a cheap and simple fix that wil tie you over for a while. cheers mates.
Posted on Mar 09, 2008
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Screeen
If it's a big tv it can just take a little while to power up, I've found that pushing channel up button switches on tv quicker but I've no idea why.
Unless you want to save power you should only be switching tv to standby, there will still be a light on the tv somewhere, blue or red it varies. TV's turn on much faster from standby than completely off.
Jul 23, 2009 | Samsung HLS4666WX 46" HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Mar 17, 2008 | Samsung HC-R5245W 52" HDTV
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
