Question about HP Deskjet F4180 All-in-One InkJet Printer
Deskjet f4185 reset ink level...
How to reset ink levels in hp f4185...........but not the taping over cartridge method please....i tested it on a officejet 5610 but it wont work so i hard resetted it...so...how to hard reset or some other methods to reset the ink levels?
  • 2 more comments
  • Anonymous Aug 14, 2008
    THE print not readable
  • Anonymous Aug 15, 2008
    how to reset inkjet cartridge
  • dbritanico_p Aug 27, 2008
    how many cc to refill ink level both black and colored hp printer,deskjet df4185
  • Mattress73 May 24, 2009
    I refilled my cartridges on my deskjet4180, and it still shows my ink levels as empty. How can I reset the ink level?
For colored is only 3ml and the black is 8ml
Posted on Apr 28, 2010
Check ink level on hp deckjet F4185
Go through computer/printer properties.
Oct 01, 2013 | HP Toner for Deskjet F4185
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Hii need to reset the hp deskjet 680c printer.i don`t know how to do this. thanks for you attention. regards.
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Jun 17, 2010 | HP DeskJet 680c InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
How do I reset the ink levels on a HP Deskjet F4200 series when I put a new ink cartridge in?
First try the information below
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
Sep 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp 3920 deskjet printer
Please check for the cartridges and try to make copies.
Aug 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
May 28, 2009 | HP DeskJet D1460 InkJet Printer
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp f4185 printer
Here is the complete problem/troubleshooting tree for your printer from HP itself!
Please follow the site and let me know if you need further assistance and also rate this solution!
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=3235312
Regards,
Ronald.
Sep 14, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
5,364 people viewed this question
Seeker5211
Seeker5211
