Question about Canon LaserCLASS 510 Printer
I have a message E100, what do I need to do? - Canon LaserCLASS 510 Printer
  • 41 Answers
From the Canon manual --
E100
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause
: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
That level of repair if it is indeed the wiring requires a qualified tech to resolve.
Posted on Mar 22, 2011
How can I fix the error e100 of canon mf3010?
Go To Below official Canon Printer Page For Your problem, PIXMA Printer Error Codes and Error Messages Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
May 05, 2014 | Canon Office Equipment & Supplies
Our canon image runner 2010f is giving an error message e100
Hi!
The e100 error reffers to the laser device in the printer. Sometimes it is not generated by a realy deffctive part, but by the fact that the metal registration roller has no proper grounding. Therefore please check the grounding springs touching the metal registration roller, to be sure that there are clean an make a firm contact with the roller. You may need to reform a little bit those springs in order to improve the contact.
Hope it helped,
Bogdan
Sep 20, 2011 | Canon imageRUNNER 2010F All-In-One Printer
CANON IMAGERUNNER 2010F HAS A MESSAGE ERROR THAT SAYS E100
The E100 error code has to do with the laser. But in this case, it may be just that the drum ahs to be replaced. How long has it been since it was replaced? They are cheap and easy to put in.
Jul 08, 2011 | Canon imageRUNNER 2010F Copier
To delete files on my iriver E100, do I have to connect to something like Windows Media Player or can I just do it straight from the E100 menu? Everytime I try it gives me the message "can not delete the...
Try this method
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 24, 2010 | iRiver E100 Digital Media Player
Problem about videos on E100
What you need is a free opensource program called http://mediacoder.sourceforge.net/download.htm
I have the settings at home but I think they were these:
Video settings: frames per second (FPS) 24 or 25, 600 KPBS
format Xvid, container AVI,
Picture settings: 320 x 240 - check the cropper settings you want
In the audio use the Lame MP3 settings no more then 44100 hz (probably 33,000).
If this doesn't work poast a message and I will get you the correct settings.
Jan 09, 2009 | iRiver E100 Digital Media Player
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
Unabe to download Video/movie onto iRiver E100
If this doesn't work post me a message and I will get you the correct settings.
Dec 23, 2008 | iRiver E100 Digital Media Player
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon LaserCLASS 510 Printer Logo
182 people viewed this question
old marine
old marine
