Question about LG Dryers
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
  • LG Master
  • 3,289 Answers
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Posted on Mar 22, 2011
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Have a DLEX5101V dryer... It won't stop spinning after the timer ends - as long as the door closed it keeps spinning.
if you can get access to your main control board be hind panel. unplug dryer then tap the control board a few times. you could have a stuck relay. plug back in and try it. may fix you problem short term.
Aug 17, 2011 | LG DLEX5101V Electric Dryer
I have a lg dryer with a 220 electric hook up plug and in my house there is only a 110 electrical outlet. is there any way I can just change out the cord to a 110 electric cord and use it?
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Jun 26, 2011 | LG Dryers
Does the dryer comes with the cord?
Most dryers purchased typically come with a power cord, as far as I know. You usually just have to install it yourself, which is a very simple process, just need a Flathead/Phillips screwdriver typically.
Mar 07, 2011 | LG DLEX5101V Electric Dryer
Having trouble connecting the dryer to the electric socket in the wall. They are differenent What do I do?
Purchase the correct wall receptical needed to fit the plug on the dryer or purchase a new cord that will work with the wall outlet to fit the dyer. Either way will work that is easiest for you
Mar 29, 2010 | Dryers
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer has the wrong 3 prongs plug on it that are curved and the outlet in my wall is straight how do i change the cord
Don't change the cord, you need the correct twist-and-lock wall receptacle installed.
It is 220 volts dryer.
Dec 06, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer plug is 4 and the electrical plug in the wall is 3
There is no "adapter" per se, you MAY be able to swap to a 3-wire cord, however that may be against local code. The only other option in that case would be to have a qualified electrician install the newer 4-wire outlet. You need to find out what you local codes are with regard to this issue. If you do change to a 3-wire cord to macth that outlet, it is critical that it be installed correctly.
Dec 14, 2008 | GE DSXH43EAWW Electric Dryer
Dryers Logo
947 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
