Question about Insignia IS-LCDTV32 32 in. Television
Picture freezes or breaksup. TV problem or cable box problem? I just changed to uverse.
  • 81 Answers
This is a Cable box/line problem not your TV call att and have a repair ticket made.
Posted on May 05, 2011
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
Had a power outage and now my TV is not showing any pictures except for the blue screenn
Outage may have changed the input channel on TV so make sure you're on the right one. Press and hold the Power button on cable box. Let that restart. Unplug the router for 10 seconds and let it boot up.
Feb 07, 2014 | AT&T UVerse
Last night my tv worked just fine this morning I go turn the tv on and there's no sound but there is a picture on my 50" Hisense flat screen tv
Check all sources , ie cable box, dvd player or video game. If all have no sound check mute setting in menu or on remote. iI just cable box or sat receiver or evan att uverse box turn them of then back on. the uverse box you may have to remove power. If still no audio request service. The problem is likely the main board or speakers .
Oct 02, 2013 | Televison & Video
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
Just install a new 42"
Can you please describe the problem with a little bit more detail? Are you saying that the pictures are coming up with a ghost effect? When the pictures are freezing what exactly do you mean, as in when changing inputs you can still see the picture there but gradually goes away?
Jan 10, 2011 | Zenith Televison & Video
Slow refresh rate - fuzzy picture on HD channels with AT&T Uverse
That would have nothing to do with the fact your TV only has a 60 hz refresh rate, the cable box will switch to the correct format just like it does with 720 or 1080 resolution.
Nov 11, 2017 | Televison & Video
Sylvania Picture on and off
it could be the mainboard is causing the trouble.
Jun 11, 2009 | Sylvania LC420SS8 LCD TV
I need ATT uverse remote control code for Onkyo AV rec TXSR304
hi just a tip! try to program your remote to control both your tv and the cable box both at the same time so when you try to adjust the volume automatically both tv and the cable box will respond. you can actually call uverse for that so that they can assist you on programming your remote to your tv and cable box. hope this would help goodluck!!!
Jan 04, 2009 | Durabrand DWT1304 13" TV
HDTV-AT&T UVERSE
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
138 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
