Question about Vacuums
Kenmore intuition with power flw, direct drive beltless system... clean all the hair from beater bar and now it wont spin...
3 Suggested Answers
  • 61 Answers
SOURCE: I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Posted on Apr 15, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: The beater bar is not
    I'm sorry to hear you're having difficulties with your DC14 Animal. The brush control system is designed to make a ratcheting noise to warn you if something jams the brushbar. To ensure everything is correct with your machine, please follow the quick troubleshooting checks shown in our online support guide:
    http://www.dyson.co.uk/support/help.asp?article=668&product=DC14-ANIMAL
    Please note, the brushbar will never rotate when the cleaner is standing upright, or if you have the brush control set to 'Hard Floors'.
    This should allow you to resolve your issue without further assistance. However, if you've followed the steps shown in the support guide and are still concerned, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you to establish the cause of the issue, and will be able to recommend the best course of action.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Sep 07, 2011
    Beater bar wont spin on kenmore intuition upright bagged vacuum
    Start with a new belt if your model has one.
    Dec 27, 2016 | Kenmore Vacuums
    Why did the brush roller stop spinning?
    With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
    Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
    Kenmore intuition non-turning beater bars, beltless model
    When you press the reset button does the vac motor start but the bars do not turn? If so the drive belt may be broken that drives the bars. If so you will have to replace the belt. If the motor does not start it is possible the belt could be jammed or the motor seized or burnt out. If it's not very old check to see if it's still under guarantee.
    Dec 07, 2014 | Kenmore Vacuums
    Kenmore canister power head not working?
    Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
    Aug 08, 2014 | Kenmore 25614 / 25615 Progressive Bagged...
    Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
    My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
    HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
    It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
    Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    My purple proggesive kenmore upright motor works but beater not beating help thank you
    I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
    Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
    Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
    Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
    Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
    After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
    Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
    My kenmore beltless upright canister vaccuum doesn't spin anymore
    Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
    Mar 24, 2009 | Kenmore Progressive Bagless Upright with...
    Vacuums Logo
    97 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
