Question about Miele Vacuums
My miele S277i will not start up The fuse is ok in plug etc Wire not broken anywhere When I opened it up I found that Power is getting all the way to the motor brushes in fact. Any ideas?? Regards Andy
  • douglas smith May 11, 2010
    motor brushes worn?
  • 438 Answers
Usually when a Miele doesn't start it's one of several things. Most commonly the cause is a faulty cord reel, however if you get power all the way to the motor brushes, it sounds as if you cord reel is ok, and that another common problem, the power switch, is also ok.
It could be your carbon brushes needed to be replaced. The carbon brushes are the only part of the motor sold separately, the rest of the parts are sold soly as a motor assembly complete. There is also a thermal switch that goes to that motor. The thermal switch will automatically shut the motor off when the motor overheats (usually caused by something stuck in the hose, or prolonged running of the machine with a full bag), and can occasionally fail itself.
Try connecting the motor itself to direct current to see if it will start. If you connect the motor to direct current, and it does come on, then you will need to replace the thermal switch, if it doesn't start connected directly to current, your motor brushes, or the motor itself have gone bad.
We can sell you either part you need, and would be happy to walk you through it. Please feel free to contact us if you have any questions.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Sep 25, 2008
  • oronoko Apr 02, 2011
    hi. i have the same problem i think is the brushes where i can get the brushes or the hole part?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Are the motor brushes worn?
Posted on Aug 03, 2008
Miele power brush switch goes and and off when vacuuming
look for loose or broken plug, try holding the plug at each end to see where the weak spot is.
If the plug isn't the problem, then look for a broken wire.
Dec 13, 2014 | Miele Vacuums
Miele S 571 worked intermittently recently then stopped for good.
have you checked the wire for any broken wire plug in and move the wire around to see if it stays running
Jan 02, 2014 | Miele S318 Bagged Canister Vacuum
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
Describe how to change power cord
Before changing the entire power cord, be certain that it is not only the plug that is not working. It is very common for the wire to break inside the insulation at the connection to the plug from flexing and bending. You can tell by plugging the vacuum in, turning it on and bending the wire at or near where it connects with the plug. If the machine stops or starts, it is probably the plug. They are available at Home Depot or Lowes or a local hardware store.
To replace the cord, you have to open the housing where the wire enters, find the end of the wire where it connects to the terminals in the vacuum and remove and install a new wire, maintaining the wire color to all connections.
Gary
Jan 15, 2011 | Miele S251 Flamenco II Bagged Canister...
It will not start. I plugged it into many different outlets and it will not start when I press the button.
this could be a faulty on/off switch or a broken lead wire or a faulty motor
Aug 07, 2010 | Miele Vacuums
Miele Red Star, small spark at outlet, no power to vacuum
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Jun 05, 2010 | Miele Red Star Bagged Canister Vacuum
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Vacuums Logo
610 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
john h
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
