Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
Is there anywhere I can buy a battery with the connectors already attatched
    Problem Solver:
  • 14 Answers
No way
Posted on Mar 22, 2011
I purchased pioneer speakers and am attempting to replace my stock speakers. Problem is there is already a plug and outlet on the factory speakers, which there is not on the new speakers. is this called ?...
yes they are called speaker harness adapters. You can just cut the factory ones off if you know the polarity (positive/negative) of the speaker wiring.
An easy way to find out is take a 9v or AA battery and two pieces of wire. Strip the wire and attatch one piece to the positive and another to the negative of your test battery, I use red wire for (+) and black for (-). Then take the other ends and touch the factory speaker connector (where it plugs onto the speaker). If it moves out or UP then you have the polarity correct and the wire that your red tester went to is the positive of the new speaker and the black test lead wire touched the negative. If the speaker moves in or DOWN then you simply have it reversed.
All pioneer speakers come with a set of wires so you can cut the factory connector off and put the new one on.
Sep 24, 2011 | Jeep Car Audio & Video
I have misplaced the power cord,what kind of power cord does this dvd use? Thanks, Mike
The power cord required is a wall wart (built in transformer) with anywhere from 9 to 12 volds DC (with center positive) and it needs to have the same connector to match the hole in the Player. Most commen good quality battery eliminators will work if they have the right connector. Try Radio Shackor possibly Best Buy. Also, the company seems to sell them but it is not worth the price and shipping. If all this is confusing, buy it from the store or factory mentioned. GTX has a web site.
G
Dec 09, 2010 | GPX PD808BU Portable DVD Player
Where can i get a tilt bracket for my rlt26cds attatchment hedge trimmer
You actually buy a different head cutter, that has the angled attachment already built in,
Oct 04, 2010 | General Hand Tools
How to replace starter on 98 sierra 5.7 2wd
on passengers side behind tire. disconnect battery, remove two wire connectors on starter, unbolt two starter bolts. New starter sometimes comes with wires attatched, cut old wires leaving lots of excess and splice wires together . Crimp connectors are usually heat shrinks. Be sure to heat them to avaiod moisture from getting into connection.
Jun 20, 2010 | 1998 GMC Sierra
Where is the ac low side service port on a 2004 chevy aveo?
NEAR firewall engine compartment TWO aluminum tubes attatched to canister
follow to connector port ONLY one will connect to the AC kit hose
so you try it if it attatches its correct
you do have to unscrew plactic cap on the low side port connector
ENGINE HAS TO BE RUNNING COMPRESSOR NEEDS TO BE ON
Jun 11, 2010 | 2004 Chevrolet Aveo
2001 gmc yukon won't start battery checks good, cant jump start won't turn over, lights come on but go dim when trying to satrt
sounds like the starter motor is jammed or shorting get someone to turn the ignition to start and at same time hit starter motor, if this does not work, put vehicle in gear and rock back and forth, this hopefully will release a stuck starter, if it is auto you obviusly cant do that, you can try attatching wires directly from your battery to the starter motor ie live to the red connector earth anywhere on the starter(not on the live terminal) and see how that works...hope that helps
Jan 30, 2010 | 2001 GMC Yukon XL
Replaced battery in 85 accord,nw no power 2 the dash an nt startn
Hi I am vortash it sounds to me that the ignition switch is not working check the connector plugs and the earth leads on the battery .. there is also usually two wires on a positive terminal of a battery one is for the starter direct and the other a smaller side attatched wire is for the utilities ( but not all cars have them check your manual ) see if yours is this type and check that wire connection . last but not least check all fuses .. under the hood and anywhere else that you may have a fuse box again check your manual ... hope this helps regards Vortash
Jul 21, 2009 | 1985 Honda Accord
Need to put in ac refrigerant
hi, you are looking for a 1/2 " aluminum tube (or painted black), when you find that, follow the tube until you find an attatched, rounded cylinder/tanks with wires attatched, when you find that, look for a blue plastic cap, if cap is present, that is your connector! if no cap present , the connector is approx. 1/2" wide, 1-1 1/2" inches tall and attatched to afor mentioned tube near tank/cylinder (actualy called receiver/drier)....good luck, marty
May 27, 2009 | 1999 Lincoln Town Car
We are trying to find a battery for our TDT 1500 teac portable phone and can't find where to buy one from anywhere.
You can send an email at the following address and they would let you know the place , where you can buy the battery from. Donnot forget to mention the place you are writting from.
parts@teac.com
Thanks
Proton
PS. If you could let me know the serial number of the battery that you already have in the phone , and where you are based , we can try finding a store near you place , where you can get the battery from.
Apr 30, 2009 | Lands Phones
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
21 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
