Question about Maytag PAV2300 Top Load Washer
How to replace timer knob on Maytag PAV 2300 aww, old one snapped off leaving just the stem
  • Maytag Master
  • 3,740 Answers
This is from another site but does a good job of explaining how to change your timer:
http://www.the-appliance-clinic.com/myttimer.html
The hardest part will be swapping the knob because you have to lift the top of it off and sometimes they can be fiesty.
WORDS OF CAUTION.
DO NOT pull all the wires off of the OLD timer. DO a ONE for ONE wire swap. i.e pull one wire from the old timer... and hook it up to the new one on the exact same terminal as the old timer.
Kelly
Posted on Mar 22, 2011
  • Kelly
    Kelly Mar 23, 2011
    Maybe I mis-interpeted your question. I had thought that your knob also broke the timer stem. You did not bother to comment and just rated the post poorly so we are not communicating well. The knob itself has a top cover that you remove. Inside the top cover there is a slide clip you remove that will release the knob from the stem and the knob is pressed upward by a spring between the knob and the dial that has the pointer.
    Lift the cover off
    Pull the slide clip
    remove the clip
    transfer the spring by placing under the new knob but on top of the pointer plate
    Press down on the knob compressing the spring and install the slide clip.
    Install the top knob cover.
    I have worked on Maytags since the mid 60's and I can help you. We just need to communicate well.
    Thanks,
    Kelly
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
I have a Maytag Performa PAV 2300 Washing Machine. Recently, clothes are still wet after spinning in the delicate cycle. This is not an issue in the Regular cycle. For now, I'm re-spinning the delicates in...
The belt is real easy to replace. Tip the washer back and yank the old belt off.
Loop the new one over the 2 small pulleys and then ease the belt over the large pulley.themobilian_2154.jpg
Important info a manual and more here
Apr 06, 2011 | Washing Machines
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
Maytag top load washing machine model PAV 2300 AWW. I've put in new springs but washing machine gets out of balance very easily. Have you got any suggestions?
If you have replaced the spring is the tub over to one side not in the center of the hole there is what they call a snumber ring on the bottom of the base the washer sets on that could be wore out but it is really hard to replace and you will need a special tool to compress the break
Apr 11, 2009 | Maytag Washing Machines
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A 6 YR. OLD MAYTAG PERFORMA PAV 2300 TOP LOADING WASHER. UNIT WORKS FINE EXCEPT FOR LOUD CLUNKING NOISE AFTER SPIN CYCLE. NOTE - ALL BRAKE COMPONENTS HAVE BEEN REPLACED.
It sounds like a spn down noise. I would check to see if the brake spring was changed when the brake and stator was. They had some problems with weak springs.
Apr 24, 2008 | Washing Machines
Pav 2300 water over fills even on a mini load past top
check the pressure line from the tub to the water level switch and make sure that it does not have a hole or crack in it if the hose is ok then the water level switch is bad
Apr 19, 2008 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag PAV2300 Top Load Washer Logo
576 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
