Question about Gigabyte GA-945GM-S2 Motherboard
4 x 512 DDR2, shows only 1GB
I had a Gigabyte GA-945GM-S2 with 2 x 512 DDR2 667MHz.
I bought another 2 x 512 DDR2 667MHz. Same type, size, speed and producer.
With the 4 x 512 DDr2, computer shows only a total of 1gb RAM, instead of 2Gb.
If i put 3 x 512, total is correctly, 1,5gb.
  • adiradu74 Aug 04, 2008
    thank you for your reply. I use dual channel, 4 x 512 mb identical ddr2. I tried every arrangement but still 1gb total. Also i have pci-express video card.
  • 659 Answers
Are you using dual channel ddr? if so resort to your manual for proper placement of it.
Posted on Aug 03, 2008
Is there any upgrade for my Bios? Bios type: Award
Why don't you look at the support section of the Gigabyte website? That is where you will need to go to download it anyway.
Sep 16, 2013 | Computers & Internet
Memory support
  1. 2 DIMM memory slots (supports up to 2GB memory)
  2. Supports 1.8V DDR DIMM
  3. Supports DDR2 533/400 DIMM
Note2: Use of a Double-Sided memory module (the single chip is 512 Mbit) is required if you wish to install a 1 GB memory module
Only supports one gig per slot...
Mar 21, 2012 | Gigabyte GA-8VM800PMD-775 Motherboard
Can you mix 1gb and 2gb dimms in the same machine (for a total of 6gb)? I added two 2gb 1066 DDR2 dimms (''OCZ'') to a PC that already had two 1066 DDR2 1gb dimms (''Kingston''). I moved the 1gb dimms to...
Your MB is AM3 with 128MB DDR3-1333 built-in, four 1.8 Volt DDR2-1200+ depending on cpu. Have you enabled cpu 64 bit extensions? Tried slowing down your memory bus?
My ASUS use dual channel for dual core cpu. I have 2 yellow and 2 black dimm sockets. Both dimms in yellow is single channel, one in yellow and one in black is dual channel. Might try 2,1,2,1 rather than 2,2,1,1 order. If only your 2 1GB dimms are seen then why do you get 4 GB from 1GB+1GB? Sounds like sockets 1,2 are giving you 4GB and 3,4 don't work? Are the 1GB+1GB in 3,4 visible if the dimms in 1,2 are removed? Per Gigabyte page your AMD Phenom II 920 is AM2+ : "Note: Due to AMD AM2+ CPU limitation, memory module DDR2 1066 or above speed is only supported by 1 dimm per channel." Per AMD (which does not show your cpu, AM3 cpu fit AM3 or AM2+ socket and support ddr2 and ddr3, AM2+ cpu only work in AM2+ socket and support ddr2 only.
Oct 16, 2009 | Computers & Internet
Ram issue - GA-8VM800PMD-775
This Type Mother Board Comes With DDR2 RAM.
Go to the Nearer Computer Pheripheral Store Ask for 1 GB or 512 DDR2 RAM..there are several brands Simmtronics,Hynix,Transcend. You can get u r choice.
Jul 08, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Warranty
contact Gigabyte at www.gigabyte.com and ask them directly. As they do not post it in specifications.
Thanks,
Lee
Jun 19, 2008 | Gigabyte GA-945GM-S2 (0818313003065)...
Gigabyte GA-945GM-S2 Motherboard Logo
77 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
