Question about Hoover Microwave Ovens
Hoover vhd822 time saver and 1200 spin lights flashing stopping mid cycle
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
Dacor DMT2420. Light and Display work fine, and you can type in time for cooking, but when you hit start, it does not make the buzz of it's normal sound, and the turntable doesn't spin.
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Jul 22, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Stopped working mid a 2 min set. no lights no clock display,
The most common cause of this type of failure during the cook cycle is the fuse melts causing a dead condition. To replace the fuse the cabinet has to be removed and the fuse replaced with the same type and amperage. Pay attention to the fuse holder to make sure it isn't burnt or corroded causing a poor connection which overheats the fuse.
Jun 21, 2010 | Kenmore 63252 Microwave Oven
Kenmore Elite HE 3t washer - stops and flashes error code F 02
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. The washer will NOT complete a cycle with the condition present that is causing the error code. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Nov 11, 2009 | Microwave Ovens
Sharp 1400W/R-2397 will start but then stop mid cycle. Not sure of problem.
Does it stop after 59 seconds?
My solution assumes so, but if not, please reply back with details.
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Sep 23, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
82 people viewed this question
Top Hoover Microwave Ovens Experts
William Miller
William Miller
Are you a Hoover Microwave Oven Expert? Answer questions, earn points and help others
