Question about LG Refrigerators
The icemaker on my lg american style fridge freezer has stopped working it looks like a piece of plastic has broken where the rod at the bottom of the ice bucket fits into the housing can it be easily fixed?
    Sergeant:
    Champion:
  • 202 Answers
Your best bet is to buy a new icemaker ... you can`t buy just icemaker parts ... its better to just buy the whole icemaker
Posted on Mar 22, 2011
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
Icemaker stops. lever to shut off icemaker frozen in place. used hair dryer to melt frozen gears and loosen lever, but water gets into gear housing again and freezes lever again
These icemakers are not repairiable.
The icemaker will need to be replaced with LG part#
AEQ36756901
This is an updated icemaker to correct the problems of past units.
Jan 17, 2010 | LG LFX25960 Bottom Freezer French Door...
I have model# FRS26R4AW5. The ice dispenser wil
Jan 09, 2010 | Electrolux Refrigerators
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Subzero 650 icemaker overflows
We had the same problem on our 650. It turns out that there is a white plastic arm attached to the icemaker shut-off switch. This plastic piece was knocked off sometime when we pulled open the freezer. I found it laying on the bottom of the freezer compartment.
I stumbled on this site while looking for the replacement part.
Look in your freezer at the icemaker. It is not easy since the upper drawer is in the way. You will see a metal wire that is the actuator for the shut-off switch. It should have a white piece of plastic clipped on the part that is closest to the ice bin. If not, or if only half of the plastic part is there, That is your problem.
Let us know if you find the part, how much it costs, where you got it.
Aug 19, 2008 | Sub-Zero 650 / O Bottom Freezer...
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
