Question about Riso Office Equipment & Supplies
I have a Risograph CR1610 and when I run the masters there is a white spot on the papers. I have looked at the cyclinder and it appears that something has been on it. Is there anything to do other than call the repairman?
  • 36 Answers
Yes, remove what's on the cylinder behind the master and that should correct your white spot.
Posted on Mar 23, 2011
Risograph cr1610 error code E78
It sounds like the EP needs to be set to "B"
May 05, 2014 | Office Equipment & Supplies
White stripes on copies
Looks like some dots of the thermal head are defective. So the master at these dots cannot be punched.
Sep 28, 2012 | Riso RP 3700
I have a Riso CR1610 and one of the drums leaks like the devil whenever I use it. Any ideas?
your drum seals are worn out you need to call for your technician to replace the seal or replace the drum unit.
Apr 22, 2010 | Riso RZ220 Duplicator
My risograph CR1610ui won't work. E03 is appearing in the display. i don't have service manual for this.
Where is the near service station for Risograph CR1610 in North East India please give me add and Pnone. no. plis
Feb 15, 2010 | Riso Office Equipment & Supplies
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
How to pull the caliper off to change the pads on 1993 mercedes 300d
Line the bottom of the master cyclinder with paper and cloth.
Loose the master cyclinder cap
GENTLELY push the piston back.
the level of the brake fluid will rise on the master cyclinder.
Slip the pads in
Close up the master cyclinder
Do a quick clean up.
IF the rotor is in GOOD shape then you will not need to pull the caliper off.
The caliper is hold down by hex head bolts.
Feb 19, 2009 | 1993 Mercedes-Benz Mercedes Benz 300 Class
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Risograph Drum
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
Sep 09, 2008 | Riso RZ220 Duplicator
Risograph CR 1610
Risograph C1610 Error E 78 - Problem was fixed by re attaching the detached cable inside the top scanner. you have to take apart the scanner on top and re attache the cable and that should get rid of the error
Aug 06, 2008 | Office Equipment & Supplies
271 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
